The user rsbarker is unable to uninstall Farmville via the Control Panel despite multiple attempts and seeks guidance. Neemobeer suggests reinstalling the program to restore any missing uninstall data, which can then be used to remove it properly. rsbarker confirms understanding of the reinstallation approach, seeking clarification. The overall tone is troubleshooting-focused with helpful suggestions.
rsbarker
I have gone to the Control Panel and selected Farmville and selected Uninstall, but no matter how many times I try, it will not initiate the unistall. How can I get this off of my computer?
If you use a cleanup utility you might have wiped out the uninstall reg keys in which case it doesn't know how to remove it.
You can install it again then uninstall which will put anything necessary to remove it.
Neemobeer
Windows Forum Team
rsbarker
Thread Author #3
Do you mean re-install the program then uninstall?
