badboy766
Ok window 7 is running very well, everything is fine and much better then both XP and Vista.
Only prob is ... i have no sound.
1stly windows coundnt find a driver so i installed 1 manualy.LOL i Downloaded 5 drivers and only 1 worked.
Still it gives an error - This device cannot start. (Code 10).
I really like this OS and i dont want to go back to the old and boring XP ;/
So please help me find a suitable driver or solution
Im using - C - Media 9739
Thx in advance ;) :p
roth227
Just looked and c-media don't list your model, so a visit to the motherboard manufacturers w/site could help.
Lee.............
roth227
Ok, found this. C-Media 9739A driver - C-Media Sound Card Drivers - CMI9739A.exe will need to free register. Also sounnds like this is happening a bit, and not just with win7. You can also try using compatibility wizard ( right click the install file and click troubleshoot compatibility, then run using recommended settings) this worked for some of the asus drivers on mine.
Cheers,
Lee......................
badboy766
Didnt work mate ty for replying ;/
Well it only happened on Win 7 never had probs on Vista or XP
roth227
Try installing the Realtek HD audio drivers, they seem to be working with the cmedia chipset on other systems. Link Removed
badboy766
Instaled the Realitech driver and when the windows powered up gave me a blue screen and i had to do a system restore ;/
so that didnt work eighther
My motherboard ID - Motherboard ID 08/04/2004-nVidia-nForce-JL61BC6CC-00
Motherboard name - Chaintech 7NJL6
this is the info hope it helps you :p
roth227
Got another one for you to try then, my god this took some finding, I can see how difficult youre finding it. anyway Link Removed - Invalid URL click on the 'external mirror link and it will download a zip containing the mainboard audio drivers. You may still need to use the compatibility wizard. Good luck.
Lee............
JessicaD
Badboy766,
Microsoft does have an official Windows 7 RC Support Forum located here Link Removed . It is supported by product specialists as well as engineers and support teams. You may want to post your question there as well for additional support.
Also, another great resource is Microsoft Springboard.
Jessica
Microsoft TechNet / Springboard
[email protected]
