Harrg
Installed Windows 7 yesterday and now my system does not detect my TV tuner. I believe I have an AverMedia A317 Mini Hybrid card. Anybody have an idea of what I can do.
Harrg
Thanks for the reply. I downloaded the driver and it still does not detect.
Saltgrass
What do you mean when you say it does not detect the card? If you open Device Manager, does it show up there?
Maybe you need some software to be able to use the card.
Harrg
Correction. It does appear in Device Manager under Sound, video and game controllers.
Harrg
bcarroll,
I'm not real technical. What do you mean try a different slot. How do I go about doing this?
Harrg
It's a HP laptop. I've been to their site; however, they only have the 32 bit version of the driver available. Not 64.
Unfortunately the links 404 so I searched for the main site here:
Harrg
bcarroll, I uninstalled driver and powered off computer. What next?
Harrg
TV tuner appears under Device Manager; however, I still receive the same error that No TV Tuner Card is detected.
Sorry if you've already tried this but have you tried right-clicking on the device in the manager, choosing properties and then update driver.. You could then point it to where the driver is located?
josephchun
go to hp.com, look up drivers for your laptop. if the tuner is meant for your laptop, you will see a driver available for download.
good luck.
