lostsoul65
"not responding due to a long running script"
This is the message I get just about everytime I go from one site to another site using IE9 on Windows 7 which makes my computer almost useless because it freezes all the time. It's not a virus. Can anyone help solve this problem?
Have you tried another browser? If another browser is ok then it points to something attached to IE. You say it's not a virus - what AV action have you tried? If not already done I'd run malwarebytes.
patcooke
Microsoft MVP
Microsoft MVP
Have you any add-onds which may be causing the problem? If unsure try disabling any you have then re-enabling one at a time.
patcooke
Microsoft MVP
Microsoft MVP
DTR
I too have this problem and it started some months ago when windows did one of it's interminable ffffff ing updates....
I have run all the MS so called fixes and still it persists............... FIXYA from MS is useless......... and why should I have to BUY some 3rd party app to fix MS screw ups/
patcooke
Microsoft MVP
Microsoft MVP
Is this a comment or a request for help? If the latter you should start a new thread rather than hijack an existing thread which is three months old.
