Also you can check if the shift key is being detected.
Press windows key + r
Type 'osk' (the on screen keyboard)
When you press the shift key it should light up on osk
- Joined
- May 25, 2009
- Messages
- 6,676
Try unplugging the keyboard and plugging it back in.
Try and update your keyboard drivers, if possible try a different keyboard.
If it doesn't work after plugging it back in, Try "Restart" and reboot the computer.
doorofnight
- Joined
- Jun 28, 2023
- Messages
- 5
I have the same issue. Tried all the youtube tips.. Also a reboot/restart or even a new WIndows configuration does not solve the problem
doorofnight
- Joined
- Jun 28, 2023
- Messages
- 5
I am not sure what you mean, but this is the keybord:
https://hitechcentury.com/wp-content/uploads/2019/05/20190526_155710-01-e1558882502306.jpeg
In Windows these are the settings: VS/Dutch and QWERTY
doorofnight
- Joined
- Jun 28, 2023
- Messages
- 5
I am so sorry, my problem is not the numeric keys, but both shift keys.
doorofnight
- Joined
- Jun 28, 2023
- Messages
- 5
sticky keys is disabled.. and with OSK the shift key does not light on. when i use an external keyboard everything is good.
Similar threads
- Replies
- 1
- Views
- 803
- Article
- Replies
- 1
- Views
- 3K
- Replies
- 1
- Views
- 2K
- Solved
- Replies
- 5
- Views
- 7K
- Solved
- Replies
- 6
- Views
- 6K
