The original poster reports persistent Windows Defender alerts about "Hive.yz" ransomware, with slow performance and high CPU usage, suspecting malware infection. A responder clarifies that malware can hide and recommends additional scans and professional help if needed. They later identify the alert as a false positive caused by a faulty signature update, advising to ignore it until Microsoft releases a fix.
HelpIhaveMalware
Today Windows Defender started giving me notifications about "Hive.yz" which is apparently ransomware and it won't shut up about it. I've clicked "Block" under the "Actions" tab after clicking the notification each time but it hasn't helped. Currently performing a full scan of my computer after 3 quick scans showed nothing. How do I remove this malware? I haven't downloaded anything off the internet lately, the only thing I've done recently is trade for a Degreaser in TF2 on Steam and I'm pretty sure it's not possible to hide malware in that. My computer is running slower than normal and Antimalware Service Executable is taking up about 90% of my CPU right now. Somebody please help
Malware does not always require user interaction to download and execute. I would start by installing a couple of extra tools and scan to validate the system is clean. Windows Defender can be disabled by malware, or if malware does get the chance to execute it ca effectively hide itself from the system including endpoint protection.
If the issue persists you may want to consider taking it to an IT shop to have it professionally fixed
Neemobeer
Windows Forum Team
