The thread discusses a user's ongoing struggle to open ports on their AT&T-provided Netgear VersaLink router for gaming, despite multiple attempts and configuring port forwarding. A helpful response provides a link to a tutorial video, but the original poster responds dismissively, accusing the responder of spamming. Overall, the conversation highlights the user's frustration with unresolved port forwarding issues and skepticism toward seemingly generic troubleshooting suggestions.
ShoobieStomper
Honorable Member
Hey, guys! Well, I have tried to resolve this issue by researching and even calling AT&T, but still no luck. I am trying to open some ports so that my brother and I can play some games together. I have done this easily in the past, but I cannot seem to figure this out. I have a Netgear VersaLink
B90-755025-15... it was provided by AT&T. In the port forwarding section, there is an option to create a new custom service... service name, protocol, start port, end port, and LAN port. I create the service and then enable it using my static IP. Anyway, it should work just fine, but the port and every other port I have tried is still closed... even after turning off my firewall. Do any of you have this problem or know how to help?
Thanks in advance! :)
- Alex
ShoobieStomper
Honorable Member
Thread Author #3
I am pretty sure you will get banned for spamming stuff like this.
