A user reports accidentally removing the power icon from the system tray on their desktop and has tried various troubleshooting steps without success. Other forum members suggest resetting system icon settings and checking related services, but no definitive solution is provided. The thread is primarily focused on resolving the missing power icon issue, with some helpful hints but no final fix yet.
Fionn Begley
I'm new to forums,only posting this so i can post links in another thread,please navigate over there as I could do with some help.
FYI The power settings are just as important to desktop computers as they are to laptops but you don't say HOW this happened so I assume the main issue now is how to fix it.
I recommend;
1. Try the reset to default settings option and if that doesn't work then,
An image from 'Power icon deleted from Systray.'. Windows settings with 'Restore default icon behaviours' and Task Manager showing running Power and PolicyAgent services.
2. Open your task manager [windows key] + [x] and then press [t]… goto the "services" tab and find "power"… is the service actually running?
Fionn Begley
Thread Author #2
Hello,I somehow fcked up and long story short I deleted the power icon from my Systray.I am on a desktop so it is not exactly necessary but my OCD is kicking in and i'm going crazy looking down on the bottom right and not seing it.When I go into notification area icons it is not there and if i go into "turn system icons on or off" I get this (see attached file) I tried deleting iconstreams and pasticonstream and restarting and it didn't fix anything.Although pasticonstreams is not there anymore iconstreams is.I have tried everything but to no avail.I have done a system restore,pretty much anything you can think of but do please give me tips on how to fix this below because this is driving me crazy,thanks in advance.
ussnorway
Windows Forum Team
I recommend;
