The user is experiencing an issue where their custom power plan settings are not retained after reboot, with the system defaulting back to the original profile. Despite configuring and creating a restore point for their maximum performance profile, the settings revert to default each time the computer is restarted, requiring manual reapplication. Replies suggest checking active power schemes with commands like `powercfg /list`, but the user notes that `powercfg` commands are not recognized, indicating a possible system or command usage issue.
MIRKOSOFT
Active Member
Hi!
I have longer time problem with power options.
I created maximum performance profile active and modified in Control Panel and Settings and saved it, even created restore point.
Computer has not to sleep or selective USB power-off or sleep, hibernate or power-off monitor etc.
Always when I reboot or power-off and then power-on computer it uses always default settings in minutes to turn off display and power-off disks and after hours go to sleep.
I know that after power-on I must to set it always again.
How to fix it?
Thank you for all in advance.
Miro
Power schemes shouldn't be getting switched on their own. I would confirm your schemas with powercfg /list and verify the correct plan is selected. and verify the settings with powercfg /query <planGUID>
Neemobeer
Windows Forum Team
MIRKOSOFT
Active Member
Thread Author #3
Simple - they're not changing by itself - only one problem that after reboot is always selected default profile.
Ok, powercfg I tested in command line as admin, it is unknown command.
Miro
