giorgos
my pc stack and later he dont do nothing and i have to restart it all time i got 2 pics i think this is the problem i hope u can help me fix it
Link Removed due to 404 Error
and the second
At least one of the file photos that you linked to, reference a dump file.
Find it, zip it up, and attach it to your next post, we could take a look and see if it includes any information that might point to the specifics of the issue.
EDIT: Also check the date and time on your computer, because the reference to the .dmp file is looking like it's from early last January. I would expect something more current.
nmsuk
Can you also open a elevated command prompt and run sfc /scannow
Trouble
Noob Whisperer
giorgos
i did it again and he show up only 1 error now but i tryed find the files but dont find anything... maybe the error is other but see the picLink Removed due to 404 Error..suggest me any program maybe it helps me
Trouble
Noob Whisperer
do a general search of you pc for *.dmp or
even better
take a look at this link
giorgos
u want me to take this files and zip it and make new thread? and upload it in my new thread?
Trouble
Noob Whisperer
If you notice the .dmp file starts with a date, if you have some of these that are reasonably current then yes, zip up three or four and attach them to your next post. There's no reason, that I can see to start a new thread.
