patlaw
Honorable Member
- Joined
- Oct 22, 2009
- Messages
- 15
I just updated an HP Elitebook 6930p laptop to Windows 7 Professional. Everything installed and is working fine. However, Windows Update reports that there are optional updates for the following two devices:
Analog Devices - Audio - SoundMAX Integrated Digital HD Audio
RICOH Company, Ltd. - Input - RICOH SmartCard Reader
Both devices work fine and have drivers installed. I believe that the installed drivers are possibly newer than these, but in any case, these drivers will not install. They fail. There's not a lot of information in the "Select the updates you want to install" window.
One option at this point is to hide the updates, which I have never done in any of the hundreds of computers I've serviced. Is there another option? Isn't there some procedure for resetting the Windows Update database on the computer?
You know the story about the fellow who was perfect; the only mistake he made was admitting that he was perfect!
