noelian14
Details: its win 7 ultimate
Aspire D255
Intel atom processor N550 1.5ghz 1mb l2 cache
1gb ddr3 memory
Problem: when i open the notebook and the sounds are enabled or even if i put music on the speakers will just give off a sound that is irritating to the ears....its like a frequency sound or something its like....a bit painful in the ears...and i dunno why it sounds like that
I can't really think of another reason your system would be having such a problem. If it was confined to only one type of sound file, I might understand.
But all I can suggest is to reinstall the sound drivers. Maybe some codec has gotten messed up.
If the unit is still in warranty, I would think about having it looked at by Aspire.
Saltgrass
Might possibly be feedback. Have you tried turning down the volume or muting the microphone?
I will assume you are referring to the built in speakers..?
noelian14
ahh...yep i tried muting mic..disabling it and uninstalling the mic...still same...and yep im referring to internal speakers :)
also tried doing in headphones...same result :(
Saltgrass
noelian14
well...i formatted my notebook and still same...reinstalled drivers from official website of acer still same it just clears a little but still same....could it be a wire?
