Lucasharmon97
I recently had re-install windows. The new installation was successful, but whenever I play a game that is full screen or use an application that is full screen, my Eyefinity gets disabled when I quit the application or Alt+Tab out of the application/game. Any way to fix this?
Experiencing issues with Eyefinity settings being disabled when exiting full-screen applications or games can be frustrating. To address this problem, you can try the following troubleshooting steps:
Adjusting Display Settings:​
  • Reconfigure Eyefinity Settings:
  • Open AMD Radeon Settings or AMD Control Center.
  • Ensure that your Eyefinity settings are properly configured for your multi-monitor setup.
  • Reset Eyefinity:
  • Sometimes, resetting Eyefinity settings and setting them up again can resolve issues.
  • Verify Display Driver:
  • Make sure you have the latest AMD graphics driver installed. Outdated drivers can sometimes cause conflicts with full-screen applications.
    Managing Full-Screen...​
  • Reset Eyefinity:
    Managing Full-Screen Behavior:​
  • Game/Application Settings:
  • Check the settings within the specific game or application to see if there are any options related to display settings that might be overriding Eyefinity configurations.
  • Windowed Full Screen:
  • Try running games in windowed full-screen mode instead, as this could prevent the Eyefinity settings from getting disabled when switching out of the game.
    Additional Steps:​
  • Monitor Cables:
  • Ensure that all the monitor cables are securely connected to the appropriate ports on your graphics card.
  • Restart Computer:
  • Rebooting the system sometimes resolves display-related issues.
  • Driver Reinstallation:
  • If the issue persists, consider uninstalling the graphics driver completely and then reinstalling it.
  • Check for Updates:
  • Keep your Windows system updated with the latest patches and updates, as they can sometimes address compatibility issues.
  • Contact AMD Support:
  • If none of the above steps work, reaching out to AMD support for specific guidance on Eyefinity settings might be beneficial.
    Conclusion:​
    By adjusting display settings, checking game/application configurations, and ensuring the proper connections, you can potentially resolve the issue of Eyefinity being disabled when exiting full-screen applications or games. Remember to keep your system and drivers up-to-date for optimal performance. If the issue persists after trying these steps, feel free to provide more details for further assistance.
