The thread involves a user seeking help finding replacement batteries for MSI GS65 Stealth Thin laptops, as they are difficult to locate locally. After initial incorrect advice about batteries for a different device, the user clarifies their need for specific laptop batteries, eventually receiving a helpful part number from another contributor. The overall tone is collaborative, with the user successfully identifying the correct battery model and expressing concerns about purchasing from Amazon due to recent strikes.
JandN2639
Well-Known Member
Several months ago, my husband and I got two (2) MSI GS65 Stealth Thin-051 15.6in Gaming Laptops.
I have not been able to find replacement batteries anywhere.
Can anyone help? We are near Chicago in Illinois.
Sent from my iPhone using Tapatalk
I look at too many posts on here. You'll need to order one online. Laptop batteries are generally very specific and no one local is likely to stock ones for your particular model.
Neemobeer
Windows Forum Team
It's a fairly standard battery, you can get them at almost any place that sells batteries. It's CR2032
Neemobeer
Windows Forum Team
Neemobeer
Windows Forum Team
JandN2639
Well-Known Member
Thread Author #9
We are avoiding Amazon. Workers went on strike yesterday because they are not provided any protection.
