pbotha
hi there,
i need some advice please. i have a new laptop with vista and i find that the sound when playing dvd's is extremely soft. the audio with music is fine.
is there anything i can do to increase the volume when playing dvd's?
i've tried all the little tweaks i can think of. is there a program i can download or something? the sound is conexant.
thanks in advance :confused:
superbill
Hi pbotha
You might like to have a look at the link below that shows 5 different ways to try and solve your problem.
Best of luck
pbotha
cheers, that worked, the vlc player had the biggest effect.
