The thread discusses display issues on a Windows 8.1 upgrade, where Metro/UI elements appear larger or have lower resolution compared to desktop windows. The original poster reports problems with the login page and Metro UI resolution after the update and mentions driver update challenges due to manufacturer validation. Contributors suggest checking browser zoom settings, updating display drivers and BIOS, and verifying hardware specifications, but overall, the issue remains unresolved, with some uncertainty about whether the problem is related to display settings or hardware drivers.
JulieA
Hello,
After the upgrade of 8.1 I got display issues because the resolution of Windows Apps (Metro UI, Internet Explorer, Login Page ...) has become lower than the resolution of windows. In my setting it is set at maximum level.
Here you can see the problem (and you can see that resolution of Chrome is at its normal level whereas resolution of IE is at a low level) :
Could you help me ? (sorry for the mistakes I'm french...!)
Thanks,
I found where the problem comes from by chance when I wanted to change my lock screen !! :)
There is an option to set the "resolution" of Metro UI here :
It was set to "Default" and I set it to "More small"
And now you can see the difference :
Before : Link Removed
After : Link Removed
brkkab
You probably need to update your display driver for Windows 8.1.AMD, nVidia and Intel all have display drivers for Windows 8.1. I'm not having any such display issue's on my desktop or notebook. Both have 8.1 and current display driver's for Windows 8.1.
Jimbo22
It's not a driver issue as much as an issue with zoom setting in the browser. It would be a driver issue if it effected all browsers but seeing how one browser is effected and the other isn't tells me it's a browser setting. Check Chromes zoom settings to what it is then set FF zoom setting to the same.
https://support.mozilla.org/en-US/kb/font-size-and-zoom-increase-size-of-web-pages
http://windows.microsoft.com/en-us/internet-explorer/ie-accessibilty-options#ie=ie-11
JulieA
Thread Author #4
Thanks for the answer. My drivers cannot been updated since I got the message "The driver hasn't been validated for this computer.. Contact the manufacturer of the computer to get the appropriate driver." (I downloaded the driver from Intel but I think ASUS has to approve the driver...).
Thanks. You are right, I don't know why I didn't look at zoom setting. I fixed the IE resolution issue by setting the zoom to 100% instead of 150%.
But I still have display issue with Metro UI :/
Jimbo22
What's the exact nature of the metro/start screen issue? Can you post some screen shots of that issue? What's the exact make/model of your notebook/netbook/laptop?
JulieA
Thread Author #6
The resolution of metro and startscreen is much lower since the update, all the elements are much "bigger" than before the update.
You can see how it's disproportionate :
I have an ASUS UX301LA-C4003P.
I don't know but maybe that was increased for tactile purpose.
Thanks,
Jimbo22
Those 2 screen shot are showing as identical on my end....I can't see a difference between the two. Also I thought this was a metro issue and not a browser or window issue. I would like to see a screen shot of your metro screen and a screen shot of your resolution settings.
JulieA
Thread Author #9
But that is very strange because before the update that was much smaller and more pleasurable to see.
Resolution settings :
Metro :
Checking your specs for the device I noticed there are a few drivers that have been updated since the device was released. In-particular your HD4400 graphics driver and your BIOS. I'd update both, especially the BIOS.
https://www.asus.com/Notebooks_Ultrabooks/ASUS_ZENBOOK_UX302LA/HelpDesk_Download/
Thanks but actually it is the UX301 model (https://www.asus.com/Notebooks_Ultrabooks/ASUS_ZENBOOK_UX301LA/HelpDesk_Download/) and I think it's updated because there is AsusLiveUpdate Center which I think update directly the driver which are on the ASUS offical website.
Thanks a lot for your help.
Jimbo22
Use this utility CPU-Z (click the hyperlink) and post a screen shot of these tabs...CPU and mainboard. This way I can verify your BIOS version. Then go to device manager and check each hardware component to verify you have the latest driver version installed from your drivers download page. If not, then update as needed.
With those new screen shots, btw thank you, I can't see anything out of the ordinary as far as resolution/fuzziness/blurry/size. You keep referring to before the update/upgrade to 8.1 and if that's the case there would be no comparison from before. This is why I can't see any difference from what you're describing to what you're posting.
JulieA
Thread Author #11
Here are the screen shot :
CPU : Link Removed
Mainboard : Link Removed
Jimbo22
So according to your screen shot you're using BIOS version 205 which is not even listed on your drivers support page. There is a version 206 which I would update to which very well might solve your problem.
This leads me to believe that there are other drivers that need updating as well like I suspected from the onset.
JulieA
Thread Author #13
Y're right ! But I don't know which file is the one for my computer (UX301LAAS206 or UX301LAS206).
EDIT : I'm going to check in the BIOS Setup.
JulieA
Thread Author #14
There isn't any information in the Bios Setup which tell me the one to take : /
And I'm downloading the 10.18.10.3308.02 (18/11/2013) driver for the graphic card because mine is a little outdated (10.18.10.3308, 16/09/2013). It's said "This driver is for Windows 8.1 upgrade.", hope it will fix the problem ! (EDIT : it didn't ! Ha : ( )
Saltgrass
There are four sizes you can select for the Metro screen apps from the right click menu, but yours look like mine also.
JulieA
Thread Author #16
Thanks ! But the 4 sizes apply just for the apps icons and not for the global UI.
Jimbo22
According to the information you provided, "I have an ASUS UX301LA-C4003P", the BIOS version you need it the top/first one. It's designated by LA and not LAA.
JulieA
Thread Author #18
It's now updated to 206 but the problem is still there.
Jimbo22
Nice job on the BIOS update! You've updated the graphics driver. We've adjusted the browsers zoom settings. Nothing left from a hardware/software issue stand point. I'm out of options...maybe contact Asus directly and explain to them what your problem is and what you've done to correct. It maybe something we've overlooked or something that Asus will have to do.
JulieA
Thread Author #20
Thanks a lot for your help ! We fixed some of the problems ! I'm going to contact Asus and will let you know when I get an answer :)
