It has nothing to do with the display, It's the sound. And I have already checked the advanced power settings before I started this topic. There is no option in there to disable it.
reghakr
- Joined
- Jan 26, 2009
- Messages
- 14,185
In order to troubleshoot your problem we need to know more detailed specs of your system hardware.
1. Go to Start > Run, and type msinfo32. then expand the Conmponents tree and choose a device
2. Go to Control Panel > Device Manager and look for any entry that has a yellow flag beside it.
3. Download System Information Viwer
4. Download PC WIZARD 2008
4 Please fill out your computers specs in the User Control Panel here on the site as well. It will then appear next to your name. look at my posting and you'll see the drop-down arrow.
The exact make an dmodel of your sound card would help us out greatly.
Calypoter
- Joined
- Jun 5, 2009
- Messages
- 14
- Thread Author
- #3
It has nothing to do with my soundcard or laptop. It works. I'm sure it's a feature in win7 to save battery.
After some time when no sound is played I see that the light of "no sound" turns on on my laptop. In the taskbar I see that my sound is not muted, it's only win7 that shutdown my soundcard. I want to disable that feature because it's anoying me more than it is good for.
reghakr
- Joined
- Jan 26, 2009
- Messages
- 14,185
OK, but if you had the right sound card driver, you would not have this problem.
If I'm getting this correctly, can't you simply mute the sound altogether?
For detailed info on laptop power option, go to Start > Help and Support and type in laptop power.
Or type in battery life. in Help and Support
Calypoter
- Joined
- Jun 5, 2009
- Messages
- 14
- Thread Author
- #5
I'm not muting the sound, it's win7 itself. It must be a battery saving feature like the one that dimms the screen after a while. I'm not having those problems on my desktop, only my laptop. I've looked where I can disable it but I don't find it. It's not in the energy scheme.
And it has nothing to do with the drivers, I have also reinstalled them.
reghakr
- Joined
- Jan 26, 2009
- Messages
- 14,185
Sorry, i just answered a question regarding the display and thought you problem was the display//
it's Hell getting old
I believe the best source of information would be to go to Start > Help and Support and type in laptop power or battery life.
Calypoter
- Joined
- Jun 5, 2009
- Messages
- 14
- Thread Author
- #9
I found in the device manager for other hardware (like the fingerprint) the option that windows can turn off the device to save energy. The sound device doesn't have this option
Thanks for helping me but I'm afraid there isn't a solution for my problem.
reghakr
- Joined
- Jan 26, 2009
- Messages
- 14,185
Sorry I couldn't help you with your problem,
Although I still believe it to be a sound card driver issue.
Going to Dells site probably does not have the most updated driver for your sound card.
I always go to the manufactures site for Ex, (Nvidia) for the latest driver.
reghakr
- Joined
- Jan 26, 2009
- Messages
- 14,185
I could only find a lower version of that driver on HP's site.
ADI SoundMAX HD Audio Driver for Microsoft Windows Vista 6.10.1.5200; (14 Aug 2007)
So it appears you are using the correct driver.
I've heard HP will not provide any Windows 7 driver until the final product is released.
Similar threads
- Article
- Replies
- 0
- Views
- 320
- Article
- Replies
- 0
- Views
- 721
- Article
- Replies
- 0
- Views
- 440
- Article
- Replies
- 2
- Views
- 2K
