Sn0wCrack
Well I had just been using a Mac theme and I was changing back to normal, but when I did everything was weird...
The Close, Maximize, Minimize were small and rectangular.
I can't even open the explorer to veiw files
Nor can I change themes back I have been using WindowsBlinds, to change to a basic blocky grey theme.
Can anyone help?
Or at least tell me what happened?
cybercore
Probably caused by WindowsBlinds, are you using a licensed and 7 compatible version? Are you trying to change themes from WB or from windows Personalization?
Elmer
Could be one of a few things.
Are you in Classic Mode?
Did Windowsblinds "unpatch" your system files but hasn't done a clean job of it? (I don't know if WB patches system files, never use it). Download this app. It can patch the three files required to run a 3rd party theme, but more importantly for you, it will tell you if they are patched or not.
(Daft one) Have you rebooted? I would be tempted to do a general clean-up as well as a full Disk Cleanup and reboot.
When you say a blocky Grey Theme, is everything like that or just parts of it? How far down the modified files road are you? if not far it may be worth running
sfc /scannow to put all your system files back to their correct state.
Lastly (for now) can you put a screen shot up?
Sn0wCrack
Well when I change from the weird theme to anothor, I can't even open Control Panel.
So WindowBlinds, is the only way to change themes.
I have patched my files before, Yes I rebooted, The Grey theme is like a Default theme
It's Windows Classic in WindowBlinds.
And a Screen of what exactly(A bit confused)
Elmer
I meant a screenshot of your desktop. If for example, you were using a 3rd party theme in Windows and the files weren't patched correctly then you'd most likely end up with a Classic Style taskbar.
Sn0wCrack
Not the case with, me my task bar is just weird in any theme that is Aero based.
There is an arrow when there are, more than 1 running.
I can't open the file explorer or Control Panel
cybercore
1. Reboot -> F8 -> System Restore
2. Boot from 7 install DVD -> Recovery options -> Command Prompt -> sfc /scannow
