The user initially reports a persistent network connectivity issue on their Windows laptop, with all networks showing a red cross and troubleshooting methods failing, suspecting a possible update or hardware issue. After attempting to revert Windows and reinstall drivers without success, they discover that the laptop can connect to other Wi-Fi networks, suggesting that the current router might be blocking the device. A contributor suggests checking router settings like MAC address filtering as a potential cause for the connectivity problem.
Benski
About two days ago, my wireless connection just got disconnected. Since then I've not been able to connect to any network be it Wi-Fi or Ethernet. I've tried everything I know and also searched for solutions online ranging from troubleshooting to using ipconfig and all, nothing seem to work.. I'm frustrated and in need of immediate help..
That could be done on the wireless router (mac address filtering) they can be blocked on a device.
From a command prompt type netsh wlan show filters to see if any networks are blocked
Benski
Thread Author #2
To elaborate,
The problem actually is that, my laptop shows that there are connections available to connect, but anytime I try to connect, it goes off as if the Wi-Fi button has been turned off and trying to connect using the Ethernet.
On my network connections window, all the networks have a red cross on them.
Troubleshooting does not provide any help at all. When I tried the ipconfig stuff, it showed IP Routing was not enabled as well as WINS Proxy. All the network adapters showed media state was disconnected
An image from 'Network connection'. Screenshot of Windows command prompt displaying IP configuration details including adapters and MAC addresses.
I don't know what else to do
patcooke
Microsoft MVP
Microsoft MVP
Looks like all your ethernet devices are down - wired and wireless. Could be a bad update. Have you recently run an update? If so try restoring back to a restore point.
Benski
Thread Author #5
To elaborate,
Troubleshooting does not provide any help at all. When I tried the ipconfig stuff, it showed IP Routing was not enabled as well as WINS Proxy. All the network adapters showed media state was disconnected View attachment 35750
Thanks very much for suggesting a solution patcooke. I've installed a previous version of windows thinking it would solve the problem but it's still the same. I downloaded a network adapters driver and tried installing but a pop-up window informed me that it "Cannot install drivers. No intel(R) Adapters are present in this computer". Please what does this mean.? I don't get it..
Moreover whenever I try connecting to a Wi-Fi network, the Wi-Fi connection disable in network connections window. Please help me..
patcooke
Microsoft MVP
Microsoft MVP
Have you checked the device manager in your control panel to see if any network devices are flagged as having a problem?
Benski
Thread Author #7
Thanks Patcooke.. All my network devices are working fine. I recently made a discovery, my laptop is able to connect to hotspot and other Wi-Fi sources. That is to say I can connect my laptop to other wireless networks from a different router. I think I might have been blocked from connecting to wireless networks on the current router I can't connect to.. Is that possible? And Is there a way or solution to it?
Neemobeer
Windows Forum Team
