The thread discusses how to remove the Cortana and search icons from the taskbar on a Windows 10 tablet. The original poster struggles with an incomplete context menu when trying to do so, and a reply suggests that the device might be in tablet mode, affecting the options. After confirming and adjusting settings, the original poster successfully resolves the issue, indicating the advice was helpful.
Nylo
Well-Known Member
I'm trying to remove the Cortana and search icon from the taskbar, but when I right-click on the taskbar I get a incomplete menu. The second photo is what it should look like. What am I doing wrong?
Thanks,
Nylo
Dell Venue Pro 8 tablet
Win 10 Home
An image from 'Taskbar Menu issue'. Tablet displaying Windows taskbar settings menu with options for icons and buttons.
Neemobeer
Windows Forum Team
I'd wager it's because it's in tablet mode.
Uncheck "Show Cortana Button" and check Search > Hidden
Nylo
Well-Known Member
Thread Author #3
You may be right about the tablet mode. I'll check it out.
I'm unable to uncheck cortina. The first photo is all I have.
Thanks for the reply
