A user reported display and visibility issues with the Windows 11 light theme, such as white boxes and unreadable text in the taskbar and settings. A helpful responder suggested updating or reinstalling the display drivers, which ultimately led to the problem being resolved through a Windows update after the user shifted from the Dev to Beta channel. The overall tone indicates the issue was fixed and advises to seek further help if needed.
DMRazerMouse
Hi All, I have the latest build in W11 fully up to date. However when I change the windows theme to 'light' the date/time and sound/network in the task bar when I hover over just turns to white boxes and when I search for something windows + S I can't see the text I am typing and lastly not all tiles show text when say I try to change something in settings.
Dark mode is fine, can see all text etc.
Any help much appreciated.
Seems that you had display driver problem. So i suggest you to download and install display driver from the manufacturer website. If you have already installed the drivers then open device manager locate your display driver and click uninstall. After uninstall system prompt you to restart so restart your machine. windows automatically reinstall the display drivers and hopefully your problem will be solved.
Interlocutor1980
DMRazerMouse
Thread Author #3
Seems to have been resolved with a Windows Update. Also moved from Dev to Beta channels.
