PcBoyGeorge
So i am on windows 7 build 7201.
Occasionly when i want to view my sd card and go to my computer i don't get a bar saying how much memory is left. Then when i click it to open the sd card it starts loading and i have that green bar where the locations thing is. I then have to restart my pc to acess it. And even worse the pc never shuts down so everytime i have to do a hard shut-down.Whats wrong!
It sounds like you are experiencing some issues with accessing your SD card on Windows 7 Build 7201, including the system not displaying the memory bar when viewing the SD card and encountering problems where the PC does not shut down correctly. Here are some troubleshooting steps you can try to address these issues:
1. SD Card Access Issue:
  • Check Connections: Ensure that your SD card is properly inserted into the card reader or slot.
  • Device Manager: Check if the SD card reader is detected in Device Manager. If there are any issues, try updating the drivers.
  • Disk Management: Open Disk Management to see if the SD card is recognized. You may need to assign a drive letter to the SD card.
    2...​
    2. Memory Bar Display Issue:
  • Explorer Settings: You can reset the Explorer settings to default by going to Folder Options > View tab > Reset Folders.
  • Check Disk Space: Even if the bar isn't showing, you can check the free space on the SD card by right-clicking on it, selecting Properties, and checking the capacity details.
    3. PC Shutdown Issue:
  • Check for Updates: Ensure your Windows 7 system is up to date with the latest patches and updates.
  • Power Settings: Check your power settings and make sure there are no issues related to the shutdown process.
  • Event Viewer: Use the Event Viewer to check for any error messages related to the shutdown process.
    Additional Tips:​
  • Running a disk check on the SD card might help in case there are any file system errors causing the loading issue.
  • Ensure that your system meets the hardware requirements for Windows 7 Build 7201 to avoid any compatibility issues. If the problems persist after trying these steps, it might be beneficial to consider backing up your data and performing a clean installation of Windows 7 Build 7201 to resolve any underlying system issues.
