The thread discusses issues caused by unlinking a Microsoft (MS) account from OneDrive, which also affected Outlook and other Office 365 apps. The original poster experienced difficulties with Outlook not starting after unlinking and considered subscribing to more storage as a solution. A contributor advises re-adding the MS account in settings or uninstalling/signing out of OneDrive to resolve the problem, and the original poster confirms success following this advice. Overall, the discussion centers on restoring functionality after unlinking a MS account from OneDrive.
Ranger
I unlinked my OneDrive account and this called trouble.
After unlinking, MS Outlook doesn't start, I can't even check my emails.
The only option was to purchase a monthly plan for storage in Onedrive.
It seems choosing Office 365 was my biggest mistake in the first place...
If you removed the MS account then it would have unlinked for all O365 apps. You will need to re-add your account under Settings > Accounts. If you do not wish to use OneDrive, you can uninstall it or sign out from Onedrive only.
Neemobeer
Windows Forum Team
Ranger
Thread Author #3
OK, got it, thanks.
AllForOne
If you removed the MS account then it would have unlinked for all O365 apps. You will need to re-add your account under Settings > Accounts. If you do not wish to use OneDrive, you can uninstall it or sign out from Onedrive only.​
It works. Thanks your answer.
