The thread discusses a user experiencing Windows 10 loading issues related to a problematic HDD. The user initially suspected the hard drive caused the problem after disconnecting it resolved the stuck load screen, but re-connecting and formatting the drive caused the issue to reoccur. Another user suggested testing the drive's health, but the original user later resolved the problem by simply repositioning the HDD's SATA cable, indicating a hardware connection issue rather than a drive failure.
Omer200158
i have found that the problem was on my hdd
in my previeus post i told i stucked on the load screen i unplugged my hdd
Windows 10 doesn't open
it didn´t happen anymore
and when i did plug in my hdd back i format it but then the computer was stuck and i was again stuck at the load screen
what´s wrong with my hdd
If you re-installed Windows and it still will not load, you most likely have a failing drive in this case or there is an issue with drivers. I would use a drive fitness test utility to test the drive. Some motherboards will have built-in tests in BIOS or use can use Hirens if you have another computer available to create a bootable disc or usb.
Neemobeer
Windows Forum Team
