The original poster reports that their refurbished Surface Pro is running slowly after cloning the original device and is seeking advice, especially about whether to revert to Windows 10 to improve performance. A responder suggests that the cloned system might be corrupt or defective and recommends running diagnostics on memory and the hard drive to identify potential issues. The overall exchange reflects troubleshooting efforts for performance problems after device replacement and cloning.
abdemiller23
I'm not sure if this is the right forum for my question...
My original Surface Pro stopped charging, so I exchanged it for a refurbished Surface Pro from Microsoft.
It is running very slowly on my new machine after I cloned the original. Maybe it's a problem with the machine rather than cloning.
It is unlikely that Microsoft will clone it or re-install all software if it agrees to replace it. I would prefer to avoid losing some important settings in the process.
To improve performance, I was advised to roll back to Windows 10, but I'm not sure if that is the best course of action...
If anyone has any more ideas on this topic, please let me know. I have not found much information on Google...
Take care
The clone could as easily be bad or carrying over corruption. You may just want to run some memory and hard drive diagnostics to see if there is an issue
Neemobeer
Windows Forum Team
