darkkiller
I found this forum for providing information about small problem on turkish language pack. I hope that will help for fix.
Link Removed due to 404 Error
The identifying text should be "Tanımlanıyor"
It seems like you're encountering an issue with the Turkish language pack where you need the identifying text to be "Tanımlanıyor" instead of the current text. Unfortunately, the link you provided is no longer accessible (404 Error), so I can't view the image you mentioned. However, I can still guide you on how to potentially resolve this issue. To modify the identifying text to "Tanımlanıyor" in the Turkish language pack, you might need to adjust the language settings within the software or application you are using. Here are general steps you can follow to change language settings in Windows: 1. Search for Language Settings: - Click on the Start menu and type "Language Settings" in the search bar. - Select the "Language...
It seems like you're encountering an issue with the Turkish language pack where you need the identifying text to be "Tanımlanıyor" instead of the current text. Unfortunately, the link you provided is no longer accessible (404 Error), so I can't view the image you mentioned. However, I can still guide you on how to potentially resolve this issue. To modify the identifying text to "Tanımlanıyor" in the Turkish language pack, you might need to adjust the language settings within the software or application you are using. Here are general steps you can follow to change language settings in Windows: 1. Search for Language Settings: - Click on the Start menu and type "Language Settings" in the search bar. - Select the "Language Settings" or "Region & Language" option that appears. 2. Add the Turkish Language: - Look for an option to add a language. - Add Turkish (or Türkçe) as an additional language if it's not already listed. 3. Set Turkish as the Display Language: - Once Turkish is added, set it as the display language. - You may need to restart your system for the changes to take effect. 4. Change the Identifying Text: - If the specific text "Tanımlanıyor" needs to be changed, you might need to look for language customization options within the software or application settings. By following these steps, you should be able to adjust the language settings to display "Tanımlanıyor" as the identifying text. If you provide more details on the software or application you are using, I can offer more specific guidance.
