JCook84
Hi, I'm not sure if this is the right place for this, but I'm having an unusual slow login problem that is very difficult to diagnose.
I just purchased a new Toshiba laptop and I have been getting it set up and removing some of the bloatware that Toshiba installs. Over the last few days I noticed that the login time when booting or unlocking has gotten much slower. It now takes 30-45 seconds. When I first got it a few weeks ago, it took less than 5 seconds.
The problem does not occur under "Safe Mode" or "Safe Mode Networking Enabled."
It DOES occur under "Diagnostic startup" in sysconfig, and it DOES occur when all the startup items and services are disabled. I tried disabling all the non-Microsoft services, and then as many of the Microsoft ones as I could. I got it down to the minimum of 4 services. The following 4 are the only ones enabled:
Group Policy Client (Microsoft)
Common Client Job Manager Service (Symantec)
RPC Endpoint Mapper (Microsoft)
Remote Desktop Services (Microsoft)
And the problem still occurred.
I did a trace of the boot. The XML is below... please note
<interval name="WinlogonInit" startTime="8569" endTime="49825" duration="41255">
Please let me know if there is anything else I can do to give you more information.
XML follows
<results timeFormat="msec">
<boot>
<processSummary numProcesses="32" numUnexpectedLonglived="19" numUnexpectedShortlived="9" numUnexpectedVeryShortlived="2">
<expectedProcesses>
<process name="System" startTime="0" endTime="-1" lifetime="-1"/>
<process name="Idle" startTime="0" endTime="-1" lifetime="-1"/>
</expectedProcesses>
<unexpectedLonglived>
<process name="smss.exe" startTime="2824" endTime="-1" lifetime="-1"/>
<process name="csrss.exe" startTime="6978" endTime="-1" lifetime="-1"/>
<process name="wininit.exe" startTime="8221" endTime="-1" lifetime="-1"/>
<process name="csrss.exe" startTime="8228" endTime="-1" lifetime="-1"/>
<process name="services.exe" startTime="8285" endTime="-1" lifetime="-1"/>
<process name="lsass.exe" startTime="8413" endTime="-1" lifetime="-1"/>
<process name="lsm.exe" startTime="8414" endTime="-1" lifetime="-1"/>
<process name="svchost.exe" startTime="8505" endTime="-1" lifetime="-1"/>
<process name="winlogon.exe" startTime="8569" endTime="-1" lifetime="-1"/>
<process name="svchost.exe" startTime="8858" endTime="-1" lifetime="-1"/>
<process name="svchost.exe" startTime="8886" endTime="-1" lifetime="-1"/>
<process name="ccSvcHst.exe" startTime="11283" endTime="-1" lifetime="-1"/>
<process name="svchost.exe" startTime="13524" endTime="-1" lifetime="-1"/>
<process name="ccSvcHst.exe" startTime="49796" endTime="-1" lifetime="-1"/>
<process name="explorer.exe" startTime="49825" endTime="-1" lifetime="-1"/>
<process name="sppsvc.exe" startTime="135087" endTime="-1" lifetime="-1"/>
<process name="dllhost.exe" startTime="176727" endTime="-1" lifetime="-1"/>
<process name="dllhost.exe" startTime="176841" endTime="-1" lifetime="-1"/>
<process name="xbootmgr.exe" startTime="176857" endTime="-1" lifetime="-1"/>
</unexpectedLonglived>
<unexpectedShortlived>
<process name="smss.exe" startTime="6600" endTime="8221" lifetime="1621"/>
<process name="smss.exe" startTime="8221" endTime="8570" lifetime="348"/>
<process name="LogonUI.exe" startTime="8891" endTime="51695" lifetime="42804"/>
<process name="dllhost.exe" startTime="49762" endTime="54806" lifetime="5044"/>
<process name="userinit.exe" startTime="49820" endTime="75892" lifetime="26072"/>
<process name="xbootmgrSleep.exe" startTime="50572" endTime="176869" lifetime="126297"/>
<process name="dllhost.exe" startTime="51169" endTime="56331" lifetime="5161"/>
<process name="xbootmgr.exe" startTime="172331" endTime="172512" lifetime="180"/>
<process name="consent.exe" startTime="173041" endTime="176838" lifetime="3797"/>
</unexpectedShortlived>
<unexpectedVeryShortlived threshold="100">
<process name="autochk.exe" startTime="2969" endTime="3053" lifetime="84"/>
<process name="AtBroker.exe" startTime="49810" endTime="49820" lifetime="9"/>
</unexpectedVeryShortlived>
</processSummary>
<timing bootDoneViaExplorer="50620" bootDoneViaPostBoot="61720" osLoaderDuration="2438"
postBootRequiredIdleTime="10000" postBootDisturbance="1100"
pnpBootStartStartTime="29" pnpBootStartEndTime="1032" pnpBootStartDuration="1003"
pnpSystemStartStartTime="2047" pnpSystemStartEndTime="2722" pnpSystemStartDuration="675">
<interval name="PreSMSS" startTime="0" endTime="2824" duration="2824">
<perProcess>
<perProcessCPUUsage name="Idle" time="2336" percentOfInterval="82.72">
<cpuUsage priority="0" time="2336" cumTime="2336" ofProcess="100.00" ofInterval="82.72" cumOfProcess="100.00"/>
</perProcessCPUUsage>
<perProcessCPUUsage name="System" time="473" percentOfInterval="16.75">
<cpuUsage priority="1" time="323" cumTime="323" ofProcess="68.29" ofInterval="11.44" cumOfProcess="68.29"/>
<cpuUsage priority="8" time="7" cumTime="330" ofProcess="1.48" ofInterval="0.25" cumOfProcess="69.77"/>
<cpuUsage priority="12" time="3" cumTime="333" ofProcess="0.63" ofInterval="0.11" cumOfProcess="70.40"/>
<cpuUsage priority="13" time="14" cumTime="347" ofProcess="2.96" ofInterval="0.50" cumOfProcess="73.36"/>
<cpuUsage priority="15" time="22" cumTime="369" ofProcess="4.65" ofInterval="0.78" cumOfProcess="78.01"/>
<cpuUsage priority="16" time="3" cumTime="373" ofProcess="0.63" ofInterval="0.11" cumOfProcess="78.86"/>
<cpuUsage priority="20" time="1" cumTime="374" ofProcess="0.21" ofInterval="0.04" cumOfProcess="79.07"/>
<cpuUsage priority="30" time="3" cumTime="377" ofProcess="0.63" ofInterval="0.11" cumOfProcess="79.70"/>
<cpuUsage priority="31" time="95" cumTime="472" ofProcess="20.08" ofInterval="3.36" cumOfProcess="99.79"/>
</perProcess>
<perPriority>
<perPriorityCPUUsage priority="0" time="2336" ofInterval="82.72">
<cpuUsage process="Idle" time="2336" ofPriority="100.00"/>
</perPriorityCPUUsage>
<perPriorityCPUUsage priority="1" time="323" ofInterval="11.44">
<cpuUsage process="System" time="323" ofPriority="100.00"/>
<perPriorityCPUUsage priority="31" time="95" ofInterval="3.36">
<cpuUsage process="System" time="95" ofPriority="100.00"/>
</perPriority>
<diskIO readBytes="39962624" readOps="1142" readTime="1770" avgBytesPerRead="34993" medBytesPerRead="32768"
writeBytes="61440" writeOps="13" writeTime="7" avgBytesPerWrite="4726" medBytesPerWrite="4096"
totalBytes="40024064" totalOps="1155" totalTime="1777">
<byFile>
<file name="Unknown (0x0)" readBytes="30668288" readOps="941" readTime="1640" writeBytes="8192" writeOps="1" writeTime="0"
totalBytes="30676480" totalOps="942" totalTime="1640"/>
<file name="bootcat.cache" readBytes="5330944" readOps="165" readTime="68" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="5330944" totalOps="165" totalTime="68"/>
<file name="$BitMap" readBytes="2097152" readOps="2" readTime="24" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="2097152" totalOps="2" totalTime="24"/>
<file name="ntdll.dll" readBytes="1732096" readOps="1" readTime="6" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="1732096" totalOps="1" totalTime="6"/>
<file name="$UsnJrnl:$J" readBytes="117760" readOps="29" readTime="12" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="117760" totalOps="29" totalTime="12"/>
<file name="$LogFile" readBytes="8192" readOps="2" readTime="9" writeBytes="53248" writeOps="12" writeTime="6"
totalBytes="61440" totalOps="14" totalTime="16"/>
<file name="$Mft" readBytes="8192" readOps="2" readTime="8" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="8192" totalOps="2" totalTime="8"/>
</byFile>
<byExtension>
<extension name="(none)" readBytes="32891392" readOps="974" readTime="1686" writeBytes="61440" writeOps="13" writeTime="7"
totalBytes="32952832" totalOps="987" totalTime="1693"/>
<extension name=".cache" readBytes="5330944" readOps="165" readTime="68" writeBytes="0" writeOps="0" writeTime="0"
<extension name=".dll" readBytes="1732096" readOps="1" readTime="6" writeBytes="0" writeOps="0" writeTime="0"
<extension name="$Mft" readBytes="8192" readOps="2" readTime="8" writeBytes="0" writeOps="0" writeTime="0"
</byExtension>
</diskIO>
</interval>
<interval name="SMSSInit" startTime="2824" endTime="8569" duration="5745">
<perProcess>
<perProcessCPUUsage name="Idle" time="4861" percentOfInterval="84.61">
<cpuUsage priority="0" time="4861" cumTime="4861" ofProcess="100.00" ofInterval="84.61" cumOfProcess="100.00"/>
<perProcessCPUUsage name="System" time="509" percentOfInterval="8.86">
<cpuUsage priority="0" time="2" cumTime="2" ofProcess="0.39" ofInterval="0.03" cumOfProcess="0.39"/>
<cpuUsage priority="8" time="135" cumTime="138" ofProcess="26.52" ofInterval="2.35" cumOfProcess="27.11"/>
<cpuUsage priority="9" time="8" cumTime="146" ofProcess="1.57" ofInterval="0.14" cumOfProcess="28.68"/>
<cpuUsage priority="12" time="230" cumTime="377" ofProcess="45.19" ofInterval="4.00" cumOfProcess="74.07"/>
<cpuUsage priority="13" time="60" cumTime="437" ofProcess="11.79" ofInterval="1.04" cumOfProcess="85.85"/>
<cpuUsage priority="14" time="2" cumTime="440" ofProcess="0.39" ofInterval="0.03" cumOfProcess="86.44"/>
<cpuUsage priority="15" time="60" cumTime="501" ofProcess="11.79" ofInterval="1.04" cumOfProcess="98.43"/>
<cpuUsage priority="16" time="7" cumTime="508" ofProcess="1.38" ofInterval="0.12" cumOfProcess="99.80"/>
<perProcessCPUUsage name="csrss.exe" time="199" percentOfInterval="3.46">
<cpuUsage priority="13" time="189" cumTime="189" ofProcess="94.97" ofInterval="3.29" cumOfProcess="94.97"/>
<cpuUsage priority="14" time="9" cumTime="198" ofProcess="4.52" ofInterval="0.16" cumOfProcess="99.50"/>
<perProcessCPUUsage name="csrss.exe" time="74" percentOfInterval="1.29">
<cpuUsage priority="13" time="2" cumTime="2" ofProcess="2.70" ofInterval="0.03" cumOfProcess="2.70"/>
<cpuUsage priority="14" time="66" cumTime="69" ofProcess="89.19" ofInterval="1.15" cumOfProcess="93.24"/>
<cpuUsage priority="15" time="5" cumTime="74" ofProcess="6.76" ofInterval="0.09" cumOfProcess="100.00"/>
</perProcess>
<perPriority>
<perPriorityCPUUsage priority="0" time="4863" ofInterval="84.65">
<cpuUsage process="Idle" time="4861" ofPriority="99.96"/>
<cpuUsage process="System" time="2" ofPriority="0.04"/>
<perPriorityCPUUsage priority="8" time="135" ofInterval="2.35">
<cpuUsage process="System" time="135" ofPriority="100.00"/>
<perPriorityCPUUsage priority="12" time="230" ofInterval="4.00">
<cpuUsage process="System" time="230" ofPriority="100.00"/>
<perPriorityCPUUsage priority="13" time="251" ofInterval="4.37">
<cpuUsage process="csrss.exe" time="189" ofPriority="75.30"/>
<cpuUsage process="System" time="60" ofPriority="23.90"/>
<cpuUsage process="csrss.exe" time="2" ofPriority="0.80"/>
<perPriorityCPUUsage priority="14" time="79" ofInterval="1.38">
<cpuUsage process="csrss.exe" time="66" ofPriority="83.54"/>
<cpuUsage process="csrss.exe" time="9" ofPriority="11.39"/>
<cpuUsage process="System" time="2" ofPriority="2.53"/>
<perPriorityCPUUsage priority="15" time="66" ofInterval="1.15">
<cpuUsage process="System" time="60" ofPriority="90.91"/>
<cpuUsage process="csrss.exe" time="5" ofPriority="7.58"/>
</perPriority>
<diskIO readBytes="135137792" readOps="2105" readTime="4992" avgBytesPerRead="64198" medBytesPerRead="36864"
writeBytes="24712704" writeOps="114" writeTime="389" avgBytesPerWrite="216778" medBytesPerWrite="5120"
totalBytes="159850496" totalOps="2219" totalTime="5382">
<byFile>
<file name="Unknown (0x0)" readBytes="74939904" readOps="2037" readTime="4183" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="74939904" totalOps="2037" totalTime="4183"/>
<file name="SOFTWARE" readBytes="56561664" readOps="1" readTime="539" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="56561664" totalOps="1" totalTime="539"/>
<file name="boot_BASE+CSWITCH+DRIVERS+POWER_1_km_premerge.etl" readBytes="0" readOps="0" readTime="0" writeBytes="20971520" writeOps="22" writeTime="343"
totalBytes="20971520" totalOps="22" totalTime="343"/>
<file name="RTKVHD64.sys" readBytes="2097152" readOps="1" readTime="22" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="2097152" totalOps="1" totalTime="22"/>
<file name="boot_BASE+CSWITCH+DRIVERS+POWER_1_um_premerge.etl" readBytes="606208" readOps="3" readTime="18" writeBytes="1048576" writeOps="3" writeTime="25"
totalBytes="1654784" totalOps="6" totalTime="44"/>
<file name="ReadyBoot.etl" readBytes="0" readOps="0" readTime="0" writeBytes="786432" writeOps="3" writeTime="3"
totalBytes="786432" totalOps="3" totalTime="3"/>
<file name="BootCKCL.etl" readBytes="0" readOps="0" readTime="0" writeBytes="655360" writeOps="6" writeTime="2"
totalBytes="655360" totalOps="6" totalTime="2"/>
<file name="{f0d813c3-94ec-11e0-a88b-e89d87ea0e23}{3808876b-c176-4e48-b7ae-04046e6cc752}" readBytes="0" readOps="0" readTime="0" writeBytes="655360" writeOps="6" writeTime="3"
totalBytes="655360" totalOps="6" totalTime="3"/>
<file name="Unknown (0xfffff8a00032b880)" readBytes="299008" readOps="6" readTime="1" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="299008" totalOps="6" totalTime="1"/>
<file name="EtwRTDiagLog.etl" readBytes="128512" readOps="5" readTime="52" writeBytes="150528" writeOps="4" writeTime="1"
totalBytes="279040" totalOps="9" totalTime="53"/>
<file name="$LogFile" readBytes="0" readOps="0" readTime="0" writeBytes="167936" writeOps="30" writeTime="3"
totalBytes="167936" totalOps="30" totalTime="3"/>
</byFile>
<byExtension>
<extension name="(none)" readBytes="132142592" readOps="2074" readTime="4793" writeBytes="888832" writeOps="51" writeTime="8"
totalBytes="133031424" totalOps="2125" totalTime="4802"/>
<extension name=".etl" readBytes="766976" readOps="13" readTime="117" writeBytes="23647744" writeOps="47" writeTime="377"
totalBytes="24414720" totalOps="60" totalTime="495"/>
<extension name=".sys" readBytes="2097152" readOps="1" readTime="22" writeBytes="8192" writeOps="2" writeTime="0"
totalBytes="2105344" totalOps="3" totalTime="23"/>
<extension name=".001" readBytes="0" readOps="0" readTime="0" writeBytes="147456" writeOps="9" writeTime="1"
totalBytes="147456" totalOps="9" totalTime="1"/>
<extension name="$Mft" readBytes="65536" readOps="16" readTime="58" writeBytes="4096" writeOps="1" writeTime="0"
totalBytes="69632" totalOps="17" totalTime="58"/>
<extension name=".regtrans-ms" readBytes="65536" readOps="1" readTime="0" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="65536" totalOps="1" totalTime="0"/>
<extension name=".dat" readBytes="0" readOps="0" readTime="0" writeBytes="16384" writeOps="4" writeTime="1"
totalBytes="16384" totalOps="4" totalTime="1"/>
</byExtension>
</diskIO>
</interval>
<winlogon numNotifications="3">
<notification type="CreateSession" sessionId="1" startTime="10097" endTime="10426" duration="329">
<subscriber name="GPClient" startTime="10097" endTime="10426" duration="328"/>
<subscriber name="TermSrv" startTime="10426" endTime="10426" duration="0"/>
</notification>
<notification type="Logon" sessionId="1" startTime="49633" endTime="49794" duration="160">
<subscriber name="Profiles" startTime="49633" endTime="49792" duration="159"/>
<subscriber name="GPClient" startTime="49792" endTime="49792" duration="0"/>
<subscriber name="TermSrv" startTime="49792" endTime="49793" duration="0"/>
<subscriber name="Sens" startTime="49793" endTime="49794" duration="0"/>
</notification>
<notification type="StartShell" sessionId="1" startTime="49818" endTime="49818" duration="0">
<subscriber name="SessionEnv" startTime="49818" endTime="49818" duration="0"/>
<subscriber name="GPClient" startTime="49818" endTime="49818" duration="0"/>
<subscriber name="Sens" startTime="49818" endTime="49818" duration="0"/>
<subscriber name="TermSrv" startTime="49818" endTime="49818" duration="0"/>
</notification>
</winlogon>
<perProcess>
<perProcessCPUUsage name="Idle" time="38266" percentOfInterval="92.75">
<cpuUsage priority="0" time="38266" cumTime="38266" ofProcess="100.00" ofInterval="92.75" cumOfProcess="100.00"/>
<perProcessCPUUsage name="LogonUI.exe" time="2548" percentOfInterval="6.18">
<cpuUsage priority="13" time="2386" cumTime="2386" ofProcess="93.64" ofInterval="5.78" cumOfProcess="93.64"/>
<cpuUsage priority="14" time="2" cumTime="2389" ofProcess="0.08" ofInterval="0.00" cumOfProcess="93.76"/>
<cpuUsage priority="15" time="158" cumTime="2547" ofProcess="6.20" ofInterval="0.38" cumOfProcess="99.96"/>
</perProcess>
<perPriority>
<perPriorityCPUUsage priority="0" time="38266" ofInterval="92.75">
<cpuUsage process="Idle" time="38266" ofPriority="100.00"/>
<perPriorityCPUUsage priority="13" time="2386" ofInterval="5.78">
<cpuUsage process="LogonUI.exe" time="2386" ofPriority="100.00"/>
</perPriority>
<diskIO readBytes="179570688" readOps="3979" readTime="9519" avgBytesPerRead="45129" medBytesPerRead="36864"
writeBytes="632852480" writeOps="923" writeTime="3952" avgBytesPerWrite="685647" medBytesPerWrite="1048576"
totalBytes="812423168" totalOps="4902" totalTime="13472">
<byFile>
<file name="boot_BASE+CSWITCH+DRIVERS+POWER_1_km_premerge.etl" readBytes="26656768" readOps="104" readTime="303" writeBytes="601882624" writeOps="582" writeTime="3587"
totalBytes="628539392" totalOps="686" totalTime="3890"/>
<file name="Unknown (0x0)" readBytes="149086208" readOps="3694" readTime="8537" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="149086208" totalOps="3694" totalTime="8537"/>
<file name="{f0d813c3-94ec-11e0-a88b-e89d87ea0e23}{3808876b-c176-4e48-b7ae-04046e6cc752}" readBytes="0" readOps="0" readTime="0" writeBytes="27705344" writeOps="166" writeTime="318"
totalBytes="27705344" totalOps="166" totalTime="318"/>
<file name="NTUSER.DAT" readBytes="1150976" readOps="1" readTime="33" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="1150976" totalOps="1" totalTime="33"/>
<file name="ReadyBoot.etl" readBytes="0" readOps="0" readTime="0" writeBytes="1048576" writeOps="4" writeTime="5"
totalBytes="1048576" totalOps="4" totalTime="5"/>
<file name="BootCKCL.etl" readBytes="0" readOps="0" readTime="0" writeBytes="655360" writeOps="6" writeTime="3"
<file name="boot_BASE+CSWITCH+DRIVERS+POWER_1_um_premerge.etl" readBytes="0" readOps="0" readTime="0" writeBytes="524288" writeOps="1" writeTime="3"
totalBytes="524288" totalOps="1" totalTime="3"/>
<file name="$LogFile" readBytes="0" readOps="0" readTime="0" writeBytes="385024" writeOps="39" writeTime="12"
totalBytes="385024" totalOps="39" totalTime="12"/>
<file name="winhttp.dll" readBytes="296960" readOps="14" readTime="16" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="296960" totalOps="14" totalTime="16"/>
<file name="dnsapi.dll" readBytes="269824" readOps="12" readTime="14" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="269824" totalOps="12" totalTime="14"/>
<file name="webio.dll" readBytes="257024" readOps="12" readTime="7" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="257024" totalOps="12" totalTime="7"/>
</byFile>
<byExtension>
<extension name=".etl" readBytes="26656768" readOps="104" readTime="303" writeBytes="604247552" writeOps="609" writeTime="3601"
totalBytes="630904320" totalOps="713" totalTime="3904"/>
<extension name="(none)" readBytes="149126144" readOps="3701" readTime="8579" writeBytes="28373504" writeOps="265" writeTime="344"
totalBytes="177499648" totalOps="3966" totalTime="8923"/>
<extension name=".dll" readBytes="2138112" readOps="131" readTime="385" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="2138112" totalOps="131" totalTime="385"/>
<extension name=".DAT" readBytes="1150976" readOps="1" readTime="33" writeBytes="1024" writeOps="1" writeTime="0"
totalBytes="1152000" totalOps="2" totalTime="33"/>
<extension name=".DLL" readBytes="261120" readOps="22" readTime="27" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="261120" totalOps="22" totalTime="27"/>
<extension name="$Mft" readBytes="57344" readOps="14" readTime="158" writeBytes="159744" writeOps="35" writeTime="4"
totalBytes="217088" totalOps="49" totalTime="163"/>
<extension name=".tmp" readBytes="49152" readOps="1" readTime="5" writeBytes="45056" writeOps="1" writeTime="0"
totalBytes="94208" totalOps="2" totalTime="6"/>
<extension name=".mui" readBytes="65536" readOps="2" readTime="7" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="65536" totalOps="2" totalTime="7"/>
<extension name=".exe" readBytes="64512" readOps="2" readTime="14" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="64512" totalOps="2" totalTime="14"/>
<extension name=".LOG1" readBytes="0" readOps="0" readTime="0" writeBytes="18432" writeOps="8" writeTime="1"
totalBytes="18432" totalOps="8" totalTime="1"/>
<extension name=".dat" readBytes="0" readOps="0" readTime="0" writeBytes="4096" writeOps="1" writeTime="0"
totalBytes="4096" totalOps="1" totalTime="0"/>
</byExtension>
</diskIO>
</interval>
<interval name="ExplorerInit" startTime="49825" endTime="50620" duration="795">
<perProcess>
<perProcessCPUUsage name="Idle" time="648" percentOfInterval="81.51">
<cpuUsage priority="0" time="648" cumTime="648" ofProcess="100.00" ofInterval="81.51" cumOfProcess="100.00"/>
<perProcessCPUUsage name="explorer.exe" time="102" percentOfInterval="12.83">
<cpuUsage priority="8" time="1" cumTime="1" ofProcess="0.98" ofInterval="0.13" cumOfProcess="0.98"/>
<cpuUsage priority="9" time="5" cumTime="6" ofProcess="4.90" ofInterval="0.63" cumOfProcess="5.88"/>
<cpuUsage priority="10" time="1" cumTime="7" ofProcess="0.98" ofInterval="0.13" cumOfProcess="6.86"/>
<cpuUsage priority="13" time="25" cumTime="33" ofProcess="24.51" ofInterval="3.14" cumOfProcess="32.35"/>
<cpuUsage priority="14" time="46" cumTime="80" ofProcess="45.10" ofInterval="5.79" cumOfProcess="78.43"/>
<cpuUsage priority="15" time="22" cumTime="102" ofProcess="21.57" ofInterval="2.77" cumOfProcess="100.00"/>
<perProcessCPUUsage name="ccSvcHst.exe" time="12" percentOfInterval="1.51">
<cpuUsage priority="9" time="12" cumTime="12" ofProcess="100.00" ofInterval="1.51" cumOfProcess="100.00"/>
<perProcessCPUUsage name="userinit.exe" time="9" percentOfInterval="1.13">
<cpuUsage priority="7" time="9" cumTime="9" ofProcess="100.00" ofInterval="1.13" cumOfProcess="100.00"/>
</perProcess>
<perPriority>
<perPriorityCPUUsage priority="0" time="648" ofInterval="81.51">
<cpuUsage process="Idle" time="648" ofPriority="100.00"/>
<perPriorityCPUUsage priority="7" time="9" ofInterval="1.13">
<cpuUsage process="userinit.exe" time="9" ofPriority="100.00"/>
<perPriorityCPUUsage priority="9" time="17" ofInterval="2.14">
<cpuUsage process="ccSvcHst.exe" time="12" ofPriority="70.59"/>
<cpuUsage process="explorer.exe" time="5" ofPriority="29.41"/>
<perPriorityCPUUsage priority="13" time="25" ofInterval="3.14">
<cpuUsage process="explorer.exe" time="25" ofPriority="100.00"/>
<perPriorityCPUUsage priority="14" time="46" ofInterval="5.79">
<cpuUsage process="explorer.exe" time="46" ofPriority="100.00"/>
<perPriorityCPUUsage priority="15" time="22" ofInterval="2.77">
<cpuUsage process="explorer.exe" time="22" ofPriority="100.00"/>
</perPriority>
<diskIO readBytes="3169792" readOps="85" readTime="524" avgBytesPerRead="37291" medBytesPerRead="32768"
writeBytes="6156288" writeOps="18" writeTime="27" avgBytesPerWrite="342016" medBytesPerWrite="204800"
totalBytes="9326080" totalOps="103" totalTime="552">
<byFile>
<file name="boot_BASE+CSWITCH+DRIVERS+POWER_1_km_premerge.etl" readBytes="0" readOps="0" readTime="0" writeBytes="4194304" writeOps="4" writeTime="17"
totalBytes="4194304" totalOps="4" totalTime="17"/>
<file name="boot_BASE+CSWITCH+DRIVERS+POWER_1_um_premerge.etl" readBytes="475136" readOps="2" readTime="16" writeBytes="524288" writeOps="1" writeTime="2"
totalBytes="999424" totalOps="3" totalTime="18"/>
<file name="IconCache.db" readBytes="915456" readOps="5" readTime="17" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="915456" totalOps="5" totalTime="17"/>
<file name="ReadyBoot.etl" readBytes="0" readOps="0" readTime="0" writeBytes="524288" writeOps="3" writeTime="3"
totalBytes="524288" totalOps="3" totalTime="3"/>
<file name="{f0d813c3-94ec-11e0-a88b-e89d87ea0e23}{3808876b-c176-4e48-b7ae-04046e6cc752}" readBytes="0" readOps="0" readTime="0" writeBytes="507904" writeOps="4" writeTime="2"
totalBytes="507904" totalOps="4" totalTime="2"/>
<file name="BootCKCL.etl" readBytes="0" readOps="0" readTime="0" writeBytes="393216" writeOps="3" writeTime="1"
totalBytes="393216" totalOps="3" totalTime="1"/>
<file name="shell32.dll" readBytes="352256" readOps="13" readTime="122" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="352256" totalOps="13" totalTime="122"/>
<file name="themeui.dll" readBytes="295936" readOps="12" readTime="27" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="295936" totalOps="12" totalTime="27"/>
<file name="segoeuib.ttf" readBytes="195072" readOps="6" readTime="12" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="195072" totalOps="6" totalTime="12"/>
<file name="explorer.exe" readBytes="155648" readOps="5" readTime="25" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="155648" totalOps="5" totalTime="25"/>
<file name="thumbcache_96.db" readBytes="98304" readOps="4" readTime="39" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="98304" totalOps="4" totalTime="39"/>
</byFile>
<byExtension>
<extension name=".etl" readBytes="475136" readOps="2" readTime="16" writeBytes="5644288" writeOps="13" writeTime="24"
totalBytes="6119424" totalOps="15" totalTime="41"/>
<extension name=".dll" readBytes="1146368" readOps="45" readTime="302" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="1146368" totalOps="45" totalTime="302"/>
<extension name=".db" readBytes="1081856" readOps="13" readTime="89" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="1081856" totalOps="13" totalTime="89"/>
<extension name="(none)" readBytes="4096" readOps="1" readTime="3" writeBytes="512000" writeOps="5" writeTime="2"
totalBytes="516096" totalOps="6" totalTime="6"/>
<extension name=".ttf" readBytes="195072" readOps="6" readTime="12" writeBytes="0" writeOps="0" writeTime="0"
<extension name=".exe" readBytes="177152" readOps="10" readTime="37" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="177152" totalOps="10" totalTime="37"/>
<extension name=".dat" readBytes="65536" readOps="2" readTime="7" writeBytes="0" writeOps="0" writeTime="0"
<extension name="$Mft" readBytes="24576" readOps="6" readTime="54" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="24576" totalOps="6" totalTime="54"/>
</byExtension>
</diskIO>
</interval>
<interval name="PostExplorerPeriod" startTime="50620" endTime="61720" duration="11100">
<perProcess>
<perProcessCPUUsage name="Idle" time="10951" percentOfInterval="98.66">
<cpuUsage priority="0" time="10951" cumTime="10951" ofProcess="100.00" ofInterval="98.66" cumOfProcess="100.00"/>
</perProcess>
<perPriority>
<perPriorityCPUUsage priority="0" time="10951" ofInterval="98.66">
<cpuUsage process="Idle" time="10951" ofPriority="100.00"/>
</perPriority>
<diskIO readBytes="2238464" readOps="111" readTime="800" avgBytesPerRead="20166" medBytesPerRead="4096"
writeBytes="8786944" writeOps="29" writeTime="72" avgBytesPerWrite="302998" medBytesPerWrite="16384"
totalBytes="11025408" totalOps="140" totalTime="873">
<byFile>
<file name="boot_BASE+CSWITCH+DRIVERS+POWER_1_km_premerge.etl" readBytes="0" readOps="0" readTime="0" writeBytes="6291456" writeOps="6" writeTime="31"
totalBytes="6291456" totalOps="6" totalTime="31"/>
<file name="boot_BASE+CSWITCH+DRIVERS+POWER_1_um_premerge.etl" readBytes="1048576" readOps="4" readTime="70" writeBytes="1048576" writeOps="2" writeTime="31"
totalBytes="2097152" totalOps="6" totalTime="102"/>
<file name="{f0d813c3-94ec-11e0-a88b-e89d87ea0e23}{3808876b-c176-4e48-b7ae-04046e6cc752}" readBytes="0" readOps="0" readTime="0" writeBytes="1114112" writeOps="8" writeTime="5"
totalBytes="1114112" totalOps="8" totalTime="5"/>
<file name="shell32.dll" readBytes="417792" readOps="13" readTime="70" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="417792" totalOps="13" totalTime="70"/>
<file name="ReadyBoot.etl" readBytes="0" readOps="0" readTime="0" writeBytes="262144" writeOps="1" writeTime="1"
totalBytes="262144" totalOps="1" totalTime="1"/>
<file name="$Mft" readBytes="159744" readOps="39" readTime="304" writeBytes="4096" writeOps="1" writeTime="0"
totalBytes="163840" totalOps="40" totalTime="304"/>
<file name="UIAnimation.dll" readBytes="96256" readOps="8" readTime="12" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="96256" totalOps="8" totalTime="12"/>
<file name="msxml3.dll" readBytes="65536" readOps="2" readTime="21" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="65536" totalOps="2" totalTime="21"/>
<file name="taskschd.dll" readBytes="65536" readOps="2" readTime="18" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="65536" totalOps="2" totalTime="18"/>
<file name="srchadmin.dll" readBytes="61952" readOps="2" readTime="22" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="61952" totalOps="2" totalTime="22"/>
<file name="mstask.dll" readBytes="52736" readOps="2" readTime="6" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="52736" totalOps="2" totalTime="6"/>
</byFile>
<byExtension>
<extension name=".etl" readBytes="1048576" readOps="4" readTime="70" writeBytes="7619584" writeOps="15" writeTime="64"
totalBytes="8668160" totalOps="19" totalTime="135"/>
<extension name="(none)" readBytes="114688" readOps="28" readTime="143" writeBytes="1163264" writeOps="13" writeTime="8"
totalBytes="1277952" totalOps="41" totalTime="151"/>
<extension name=".dll" readBytes="862208" readOps="33" readTime="203" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="862208" totalOps="33" totalTime="203"/>
<extension name="$Mft" readBytes="159744" readOps="39" readTime="304" writeBytes="4096" writeOps="1" writeTime="0"
<extension name=".db" readBytes="32768" readOps="1" readTime="12" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="32768" totalOps="1" totalTime="12"/>
<extension name=".exe" readBytes="12288" readOps="1" readTime="18" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="12288" totalOps="1" totalTime="18"/>
<extension name=".ini" readBytes="8192" readOps="5" readTime="47" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="8192" totalOps="5" totalTime="47"/>
</byExtension>
</diskIO>
</interval>
<interval name="TraceTail" startTime="61720" endTime="178428" duration="116708">
<prefetch>
<scenario name="SPPSVC.EXE" hash="0xb0f8131b" type="applaunch" openVolumesStartTime="135103" openVolumesEndTime="135103" openVolumesDuration="0">
<phase index="0" type="metadata" startTime="135103" endTime="135143" duration="39"
isTricklePhase="false" pagesPrefetched="0" readLists="0" readBytes="299008" readOps="6"
process="sppsvc.exe" pid="1480" tid="1484"/>
<phase index="0" type="data" startTime="135143" endTime="135153" duration="10"
isTricklePhase="false" pagesPrefetched="73" readLists="20" readBytes="8192" readOps="2"
<phase index="0" type="image" startTime="135153" endTime="135249" duration="96"
isTricklePhase="false" pagesPrefetched="768" readLists="18" readBytes="2946560" readOps="19"
</scenario>
<scenario name="XBOOTMGR.EXE" hash="0x8263141d" type="applaunch" openVolumesStartTime="172339" openVolumesEndTime="172339" openVolumesDuration="0">
<phase index="0" type="metadata" startTime="172339" endTime="172369" duration="30"
isTricklePhase="false" pagesPrefetched="0" readLists="0" readBytes="110592" readOps="4"
process="xbootmgr.exe" pid="1548" tid="1552"/>
<phase index="0" type="data" startTime="172369" endTime="172456" duration="86"
isTricklePhase="false" pagesPrefetched="259" readLists="45" readBytes="186880" readOps="12"
<phase index="0" type="image" startTime="172456" endTime="172511" duration="54"
isTricklePhase="false" pagesPrefetched="1156" readLists="40" readBytes="720384" readOps="24"
</scenario>
<scenario name="CONSENT.EXE" hash="0x531bd9ea" type="applaunch" openVolumesStartTime="173056" openVolumesEndTime="173056" openVolumesDuration="0">
<phase index="0" type="metadata" startTime="173056" endTime="173142" duration="85"
isTricklePhase="false" pagesPrefetched="0" readLists="0" readBytes="1335296" readOps="10"
process="consent.exe" pid="1572" tid="1576"/>
<phase index="0" type="data" startTime="173142" endTime="173234" duration="92"
isTricklePhase="false" pagesPrefetched="1355" readLists="87" readBytes="4029440" readOps="9"
<phase index="0" type="image" startTime="173234" endTime="173323" duration="88"
isTricklePhase="false" pagesPrefetched="2090" readLists="72" readBytes="403968" readOps="20"
</scenario>
<scenario name="DLLHOST.EXE" hash="0x0c6ad872" type="applaunch" openVolumesStartTime="176747" openVolumesEndTime="176747" openVolumesDuration="0">
<phase index="0" type="data" startTime="176747" endTime="176767" duration="20"
isTricklePhase="false" pagesPrefetched="186" readLists="32" readBytes="57344" readOps="2"
process="dllhost.exe" pid="1636" tid="1640"/>
</scenario>
<scenario name="DLLHOST.EXE" hash="0x0c6ad872" type="applaunch" openVolumesStartTime="176842" openVolumesEndTime="176842" openVolumesDuration="0"/>
<scenario name="XBOOTMGR.EXE" hash="0x8263141d" type="applaunch" openVolumesStartTime="176859" openVolumesEndTime="176859" openVolumesDuration="0"/>
</prefetch>
<perProcess>
<perProcessCPUUsage name="Idle" time="116280" percentOfInterval="99.63">
<cpuUsage priority="0" time="116280" cumTime="116280" ofProcess="100.00" ofInterval="99.63" cumOfProcess="100.00"/>
</perProcess>
<perPriority>
<perPriorityCPUUsage priority="0" time="116280" ofInterval="99.63">
<cpuUsage process="Idle" time="116280" ofPriority="100.00"/>
</perPriority>
<diskIO readBytes="19230720" readOps="539" readTime="2564" avgBytesPerRead="35678" medBytesPerRead="16384"
writeBytes="22082048" writeOps="124" writeTime="145" avgBytesPerWrite="178081" medBytesPerWrite="4096"
totalBytes="41312768" totalOps="663" totalTime="2709">
<byFile>
<file name="boot_BASE+CSWITCH+DRIVERS+POWER_1_km_premerge.etl" readBytes="0" readOps="0" readTime="0" writeBytes="19922944" writeOps="19" writeTime="99"
totalBytes="19922944" totalOps="19" totalTime="99"/>
<file name="sppsvc.exe" readBytes="4685824" readOps="91" readTime="283" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="4685824" totalOps="91" totalTime="283"/>
<file name="Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat" readBytes="3753984" readOps="2" readTime="39" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="3753984" totalOps="2" totalTime="39"/>
<file name="sppobjs.dll" readBytes="1089024" readOps="41" readTime="94" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="1089024" totalOps="41" totalTime="94"/>
<file name="boot_BASE+CSWITCH+DRIVERS+POWER_1_um_premerge.etl" readBytes="524288" readOps="2" readTime="2" writeBytes="524288" writeOps="1" writeTime="2"
totalBytes="1048576" totalOps="3" totalTime="4"/>
<file name="{F750E6C3-38EE-11D1-85E5-00C04FC295EE}" readBytes="786432" readOps="1" readTime="11" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="786432" totalOps="1" totalTime="11"/>
<file name="monitor.PNF" readBytes="696320" readOps="24" readTime="37" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="696320" totalOps="24" totalTime="37"/>
<file name="$Mft" readBytes="520192" readOps="76" readTime="550" writeBytes="118784" writeOps="26" writeTime="6"
totalBytes="638976" totalOps="102" totalTime="557"/>
<file name="machine.PNF" readBytes="569344" readOps="20" readTime="71" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="569344" totalOps="20" totalTime="71"/>
<file name="{f0d813c3-94ec-11e0-a88b-e89d87ea0e23}{3808876b-c176-4e48-b7ae-04046e6cc752}" readBytes="0" readOps="0" readTime="0" writeBytes="557056" writeOps="4" writeTime="2"
totalBytes="557056" totalOps="4" totalTime="2"/>
<file name="spsys.sys" readBytes="429056" readOps="15" readTime="22" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="429056" totalOps="15" totalTime="22"/>
</byFile>
<byExtension>
<extension name=".etl" readBytes="524288" readOps="2" readTime="2" writeBytes="21111808" writeOps="28" writeTime="105"
totalBytes="21636096" totalOps="30" totalTime="108"/>
<extension name=".exe" readBytes="5082624" readOps="112" readTime="401" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="5082624" totalOps="112" totalTime="401"/>
<extension name=".dll" readBytes="4195840" readOps="185" readTime="710" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="4195840" totalOps="185" totalTime="710"/>
<extension name=".cat" readBytes="3753984" readOps="2" readTime="39" writeBytes="0" writeOps="0" writeTime="0"
<extension name=".PNF" readBytes="2426368" readOps="101" readTime="511" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="2426368" totalOps="101" totalTime="511"/>
<extension name="(none)" readBytes="1525760" readOps="19" readTime="121" writeBytes="828416" writeOps="67" writeTime="33"
totalBytes="2354176" totalOps="86" totalTime="154"/>
<extension name="$Mft" readBytes="520192" readOps="76" readTime="550" writeBytes="118784" writeOps="26" writeTime="6"
<extension name=".sys" readBytes="461824" readOps="16" readTime="31" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="461824" totalOps="16" totalTime="31"/>
<extension name=".pf" readBytes="313344" readOps="4" readTime="48" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="313344" totalOps="4" totalTime="48"/>
<extension name=".cpl" readBytes="139264" readOps="8" readTime="18" writeBytes="0" writeOps="0" writeTime="0"
totalBytes="139264" totalOps="8" totalTime="18"/>
<extension name=".dat" readBytes="100864" readOps="1" readTime="9" writeBytes="4096" writeOps="1" writeTime="0"
totalBytes="104960" totalOps="2" totalTime="10"/>
</byExtension>
</diskIO>
</interval>
</timing>
<services autoStartStartTime="8482" autoStartEndTime="15056" autoStartDuration="6573">
<serviceTransition name="PlugPlay" group="PlugPlay" transition="start"
totalTransitionTimeDelta="33" firstCheckpointTimeDelta="25" processingTimeDelta="8"
container="DcomLaunch svchost (772)" startedAt="8482" firstCheckpointedAt="8507" endedAt="8516"/>
<serviceTransition name="DcomLaunch" group="COM Infrastructure" transition="start"
totalTransitionTimeDelta="3" firstCheckpointTimeDelta="0" processingTimeDelta="3"
container="DcomLaunch svchost (772)" startedAt="8584" firstCheckpointedAt="8584" endedAt="8588"/>
<serviceTransition name="RpcEptMapper" group="COM Infrastructure" transition="start"
totalTransitionTimeDelta="279" firstCheckpointTimeDelta="275" processingTimeDelta="3"
container="RPCSS svchost (880)" startedAt="8584" firstCheckpointedAt="8860" endedAt="8864"/>
<serviceTransition name="RpcSs" group="COM Infrastructure" transition="start"
totalTransitionTimeDelta="20" firstCheckpointTimeDelta="0" processingTimeDelta="20"
container="RPCSS svchost (880)" startedAt="8864" firstCheckpointedAt="8864" endedAt="8884"/>
<serviceTransition name="gpsvc" group="ProfSvc_Group" transition="start"
totalTransitionTimeDelta="1541" firstCheckpointTimeDelta="8" processingTimeDelta="1532"
container="netsvcs svchost (944)" startedAt="8884" firstCheckpointedAt="8893" endedAt="10426"/>
<serviceTransition name="ProfSvc" group="ProfSvc_Group" transition="start"
totalTransitionTimeDelta="1540" firstCheckpointTimeDelta="0" processingTimeDelta="1540"
container="netsvcs svchost (944)" startedAt="8894" firstCheckpointedAt="8894" endedAt="10434"/>
<serviceTransition name="PCCUJobMgr" group="" transition="start"
totalTransitionTimeDelta="4600" firstCheckpointTimeDelta="3054" processingTimeDelta="1545"
container="diMaster.dll /prefetch:1 (532)" startedAt="10456" firstCheckpointedAt="13511" endedAt="15056"/>
<serviceTransition name="TermService" group="" transition="start"
totalTransitionTimeDelta="93" firstCheckpointTimeDelta="7" processingTimeDelta="85"
container="NetworkService svchost (668)" startedAt="13521" firstCheckpointedAt="13529" endedAt="13615"/>
<serviceTransition name="sppsvc" group="" transition="start"
totalTransitionTimeDelta="317" firstCheckpointTimeDelta="192" processingTimeDelta="125"
container="sppsvc.exe (1480)" startedAt="135062" firstCheckpointedAt="135254" endedAt="135379"/>
<serviceTransition name="Appinfo" group="" transition="start"
totalTransitionTimeDelta="11" firstCheckpointTimeDelta="0" processingTimeDelta="11"
container="netsvcs svchost (944)" startedAt="172513" firstCheckpointedAt="172513" endedAt="172525"/>
</services>
<pnp>
<phase name="bootStart" startTime="29" endTime="1032" duration="1003">
<pnpObject name="IDE\DiskHitachi_HTS725050A9A360_________________PC4OC71E\4+80f037e+0+0.0.0" type="Device" activity="Start"
startTime="451" endTime="657" duration="205" prePendTime="205" description="Disk drive" friendlyName="Hitachi HTS725050A9A360"/>
<pnpObject name="PCI\VEN_8086+DEV_1C03+SUBSYS_00011179+REV_04\3+11583659+1+FA" type="Device" activity="Enum"
startTime="377" endTime="431" duration="54" prePendTime="54" description="Intel® Mobile Express Chipset SATA AHCI Controller" friendlyName=""/>
<pnpObject name="PCI\VEN_8086+DEV_1C03+SUBSYS_00011179+REV_04\3+11583659+1+FA" type="Device" activity="Start"
startTime="344" endTime="376" duration="32" prePendTime="32" description="Intel® Mobile Express Chipset SATA AHCI Controller" friendlyName=""/>
<pnpObject name="PCI\VEN_8086+DEV_1C14+SUBSYS_00011179+REV_B4\3+11583659+1+E2" type="Device" activity="Start"
startTime="203" endTime="234" duration="31" prePendTime="31" description="Intel® 6 Series/C200 Series Chipset Family PCI Express Root Port 3 - 1C14" friendlyName=""/>
<pnpObject name="PCI\VEN_8086+DEV_2448+SUBSYS_00011179+REV_B4\3+11583659+1+E6" type="Device" activity="Start"
startTime="296" endTime="327" duration="30" prePendTime="30" description="Intel® 82801 PCI Bridge - 2448" friendlyName=""/>
<pnpObject name="PCI\VEN_8086+DEV_1C1A+SUBSYS_00011179+REV_B4\3+11583659+1+E5" type="Device" activity="Start"
startTime="267" endTime="296" duration="29" prePendTime="29" description="Intel® 6 Series/C200 Series Chipset Family PCI Express Root Port 6 - 1C1A" friendlyName=""/>
<pnpObject name="PCI\VEN_8086+DEV_1C10+SUBSYS_00011179+REV_B4\3+11583659+1+E0" type="Device" activity="Start"
startTime="143" endTime="171" duration="28" prePendTime="28" description="Intel® 6 Series/C200 Series Chipset Family PCI Express Root Port 1 - 1C10" friendlyName=""/>
<pnpObject name="PCI\VEN_8086+DEV_1C18+SUBSYS_00011179+REV_B4\3+11583659+1+E4" type="Device" activity="Start"
startTime="237" endTime="265" duration="27" prePendTime="27" description="Intel® 6 Series/C200 Series Chipset Family PCI Express Root Port 5 - 1C18" friendlyName=""/>
<pnpObject name="PCI\VEN_8086+DEV_1C12+SUBSYS_00011179+REV_B4\3+11583659+1+E1" type="Device" activity="Start"
startTime="177" endTime="202" duration="24" prePendTime="24" description="Intel® 6 Series/C200 Series Chipset Family PCI Express Root Port 2 - 1C12" friendlyName=""/>
<pnpObject name="ACPI_HAL\PNP0C08\0" type="Device" activity="Start"
startTime="36" endTime="57" duration="20" prePendTime="20" description="Microsoft ACPI-Compliant System" friendlyName=""/>
<pnpObject name="PCI\VEN_8086+DEV_0101+SUBSYS_00011179+REV_09\3+11583659+1+08" type="Device" activity="Start"
startTime="122" endTime="140" duration="17" prePendTime="17" description="2nd generation Intel® Core™ processor family PCI Express Controller - 0101" friendlyName=""/>
<pnpObject name="ACPI\PNP0A08\0" type="Device" activity="Enum"
startTime="77" endTime="94" duration="17" prePendTime="17" description="PCI bus" friendlyName=""/>
</phase>
<phase name="systemStart" startTime="2047" endTime="2722" duration="675">
<pnpObject name="cdrom" type="Driver" activity="Load"
startTime="2047" endTime="2291" duration="243" prePendTime="243"/>
<pnpObject name="MpFilter" type="Driver" activity="Load"
startTime="2291" endTime="2415" duration="124" prePendTime="124"/>
<pnpObject name="VgaSave" type="Driver" activity="Load"
startTime="2417" endTime="2465" duration="48" prePendTime="48"/>
<pnpObject name="TermDD" type="Driver" activity="Load"
startTime="2627" endTime="2657" duration="29" prePendTime="29"/>
<pnpObject name="CSC" type="Driver" activity="Load"
startTime="2694" endTime="2720" duration="25" prePendTime="25"/>
<pnpObject name="rdbss" type="Driver" activity="Load"
startTime="2657" endTime="2682" duration="24" prePendTime="24"/>
<pnpObject name="AFD" type="Driver" activity="Load"
startTime="2548" endTime="2572" duration="24" prePendTime="24"/>
<pnpObject name="tdx" type="Driver" activity="Load"
startTime="2524" endTime="2548" duration="23" prePendTime="23"/>
<pnpObject name="RDPREFMP" type="Driver" activity="Load"
startTime="2486" endTime="2505" duration="18" prePendTime="18"/>
<pnpObject name="WfpLwf" type="Driver" activity="Load"
startTime="2577" endTime="2590" duration="13" prePendTime="13"/>
<pnpObject name="NetBIOS" type="Driver" activity="Load"
startTime="2602" endTime="2615" duration="12" prePendTime="12"/>
<pnpObject name="RDPENCDD" type="Driver" activity="Load"
startTime="2473" endTime="2486" duration="12" prePendTime="12"/>
<pnpObject name="Serial" type="Driver" activity="Load"
startTime="2615" endTime="2626" duration="10" prePendTime="10"/>
<pnpObject name="Npfs" type="Driver" activity="Load"
startTime="2514" endTime="2524" duration="10" prePendTime="10"/>
<pnpObject name="mssmbios" type="Driver" activity="Load"
startTime="2683" endTime="2693" duration="10" prePendTime="10"/>
</phase>
<phase name="remainder" startTime="2722" endTime="-1" duration="-1">
<pnpObject name="amdkmdap" type="Driver" activity="Load"
startTime="2772" endTime="3932" duration="1159" prePendTime="1159"/>
<pnpObject name="amdkmdag" type="Driver" activity="Load"
startTime="2840" endTime="3918" duration="1077" prePendTime="1077"/>
<pnpObject name="ACPI\PNP0F13\4+e54c8b+0" type="Device" activity="Start"
startTime="5871" endTime="6318" duration="447" prePendTime="0" description="Alps Pointing-device" friendlyName=""/>
<pnpObject name="USB\VID_8087+PID_0024\5+106582c+0+1" type="Device" activity="Start"
startTime="7551" endTime="7879" duration="328" prePendTime="328" description="Generic USB Hub" friendlyName=""/>
<pnpObject name="USB\VID_8087+PID_0024\5+c5c6cc1+0+1" type="Device" activity="Start"
startTime="7222" endTime="7550" duration="327" prePendTime="327" description="Generic USB Hub" friendlyName=""/>
<pnpObject name="USB\VID_08FF+PID_168B\6+14d3242a+0+1" type="Device" activity="Start"
startTime="7891" endTime="8205" duration="313" prePendTime="0" description="AuthenTec Inc. AES1660" friendlyName=""/>
<pnpObject name="MEIx64" type="Driver" activity="Load"
startTime="3935" endTime="4248" duration="313" prePendTime="313"/>
<pnpObject name="PCI\VEN_8086+DEV_1502+SUBSYS_00011179+REV_04\3+11583659+1+C8" type="Device" activity="Start"
startTime="5288" endTime="5567" duration="279" prePendTime="279" description="Intel® 82579LM Gigabit Network Connection" friendlyName=""/>
<pnpObject name="ACPI\IFX0102\4+e54c8b+0" type="Device" activity="Start"
startTime="5871" endTime="6145" duration="274" prePendTime="0" description="Trusted Platform Module 1.2" friendlyName=""/>
<pnpObject name="NUSB3\ROOT_HUB30\5+10f280af+0" type="Device" activity="Start"
startTime="6319" endTime="6505" duration="185" prePendTime="185" description="Renesas Electronics USB 3.0 Root Hub" friendlyName=""/>
<pnpObject name="cdfs" type="Driver" activity="Load"
startTime="6548" endTime="6704" duration="155" prePendTime="155"/>
<pnpObject name="NETwNs64" type="Driver" activity="Load"
startTime="4445" endTime="4593" duration="147" prePendTime="147"/>
<pnpObject name="ApfiltrService" type="Driver" activity="Load"
startTime="4639" endTime="4772" duration="132" prePendTime="132"/>
<pnpObject name="PCI\VEN_8086+DEV_1C3A+SUBSYS_00011179+REV_04\3+11583659+1+B0" type="Device" activity="Start"
startTime="5132" endTime="5232" duration="100" prePendTime="100" description="Intel® Management Engine Interface" friendlyName=""/>
<pnpObject name="PCI\VEN_1002+DEV_AA98+SUBSYS_00011179+REV_00\4+31185f9+0+0108" type="Device" activity="Start"
startTime="5039" endTime="5132" duration="92" prePendTime="92" description="High Definition Audio Controller" friendlyName=""/>
<pnpObject name="PCI\VEN_8086+DEV_1C20+SUBSYS_00011179+REV_04\3+11583659+1+D8" type="Device" activity="Start"
startTime="5593" endTime="5678" duration="84" prePendTime="0" description="High Definition Audio Controller" friendlyName=""/>
<pnpObject name="e1cexpress" type="Driver" activity="Load"
startTime="4249" endTime="4334" duration="84" prePendTime="84"/>
<pnpObject name="PCI\VEN_1033+DEV_0194+SUBSYS_00011179+REV_04\4+61df60c+0+00E4" type="Device" activity="Start"
startTime="5752" endTime="5833" duration="80" prePendTime="80" description="Renesas Electronics USB 3.0 Host Controller" friendlyName=""/>
<pnpObject name="rixdpcie" type="Driver" activity="Load"
startTime="4365" endTime="4445" duration="80" prePendTime="80"/>
<pnpObject name="PCI\VEN_8086+DEV_0082+SUBSYS_13018086+REV_34\4+27e2eb1f+0+00E2" type="Device" activity="Start"
startTime="5680" endTime="5752" duration="72" prePendTime="72" description="Intel® Centrino® Advanced-N 6205" friendlyName=""/>
<pnpObject name="NdisTapi" type="Driver" activity="Load"
startTime="4868" endTime="4941" duration="72" prePendTime="72"/>
<pnpObject name="luafv" type="Driver" activity="Load"
startTime="8519" endTime="8584" duration="64" prePendTime="64"/>
<pnpObject name="HDAUDIO\FUNC_01+VEN_10EC+DEV_0269+SUBSYS_11790628+REV_1001\4+129309d+0+0001" type="Device" activity="Start"
startTime="6319" endTime="6384" duration="64" prePendTime="0" description="Realtek High Definition Audio" friendlyName=""/>
<pnpObject name="PCI\VEN_8086+DEV_1C3D+SUBSYS_00011179+REV_04\3+11583659+1+B3" type="Device" activity="Start"
startTime="5232" endTime="5287" duration="55" prePendTime="55" description="Intel® Active Management Technology - SOL" friendlyName="Intel® Active Management Technology - SOL (COM3)"/>
<pnpObject name="IntcAzAudAddService" type="Driver" activity="Load"
startTime="6157" endTime="6207" duration="50" prePendTime="50"/>
<pnpObject name="tunnel" type="Driver" activity="Load"
startTime="2723" endTime="2769" duration="46" prePendTime="46"/>
<pnpObject name="TVALZFL" type="Driver" activity="Load"
startTime="4786" endTime="4828" duration="42" prePendTime="42"/>
<pnpObject name="PCI\VEN_8086+DEV_1C26+SUBSYS_00011179+REV_04\3+11583659+1+E8" type="Device" activity="Start"
startTime="5835" endTime="5870" duration="34" prePendTime="34" description="Intel® 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26" friendlyName=""/>
<pnpObject name="PCI\VEN_1180+DEV_E823+SUBSYS_00011179+REV_04\4+32e69fa8+0+00E0" type="Device" activity="Start"
startTime="5593" endTime="5625" duration="31" prePendTime="31" description="Ricoh PCIe SDXC/MMC Host Controller" friendlyName="Ricoh PCIe SDXC/MMC Host Controller"/>
<pnpObject name="PCI\VEN_1180+DEV_E852+SUBSYS_00011179+REV_07\4+32e69fa8+0+02E0" type="Device" activity="Start"
startTime="5648" endTime="5680" duration="31" prePendTime="31" description="Ricoh PCIe xD-Picture Card Controller" friendlyName="Ricoh PCIe xD-Picture Card Controller"/>
<pnpObject name="IDE\CdRomMATs***A_DVD-RAM_UJ8A2AS________________1.00____\4+80f037e+0+0.1.0" type="Device" activity="Start"
startTime="5871" endTime="5897" duration="25" prePendTime="25" description="CD-ROM Drive" friendlyName="MATs***A DVD-RAM UJ8A2AS"/>
<pnpObject name="PCI\VEN_1180+DEV_E232+SUBSYS_00011179+REV_04\4+32e69fa8+0+01E0" type="Device" activity="Start"
startTime="5625" endTime="5648" duration="23" prePendTime="23" description="Ricoh PCIe Memory Stick Host Controller" friendlyName="Ricoh PCIe Memory Stick Host Controller"/>
<pnpObject name="PCI\VEN_8086+DEV_1C2D+SUBSYS_00011179+REV_04\3+11583659+1+D0" type="Device" activity="Start"
startTime="5567" endTime="5589" duration="21" prePendTime="21" description="Intel® 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D" friendlyName=""/>
<pnpObject name="PCI\VEN_1002+DEV_6760+SUBSYS_00031179+REV_00\4+31185f9+0+0008" type="Device" activity="Start"
startTime="5017" endTime="5039" duration="21" prePendTime="21" description="AMD Radeon HD 6450M " friendlyName=""/>
<pnpObject name="risdxc" type="Driver" activity="Load"
startTime="4340" endTime="4361" duration="20" prePendTime="20"/>
<pnpObject name="swenum" type="Driver" activity="Load"
startTime="4962" endTime="4979" duration="16" prePendTime="16"/>
<pnpObject name="i8042prt" type="Driver" activity="Load"
startTime="4612" endTime="4629" duration="16" prePendTime="16"/>
<pnpObject name="nusb3xhc" type="Driver" activity="Load"
startTime="4595" endTime="4610" duration="15" prePendTime="15"/>
<pnpObject name="Rasl2tp" type="Driver" activity="Load"
startTime="4853" endTime="4868" duration="15" prePendTime="15"/>
<pnpObject name="umbus" type="Driver" activity="Load"
startTime="4980" endTime="4994" duration="14" prePendTime="14"/>
<pnpObject name="DXGKrnl" type="Driver" activity="Load"
startTime="3918" endTime="3932" duration="14" prePendTime="14"/>
<pnpObject name="CmBatt" type="Driver" activity="Load"
startTime="4829" endTime="4841" duration="12" prePendTime="12"/>
<pnpObject name="NdisWan" type="Driver" activity="Load"
startTime="4941" endTime="4952" duration="11" prePendTime="11"/>
<pnpObject name="kbdclass" type="Driver" activity="Load"
startTime="4629" endTime="4639" duration="10" prePendTime="10"/>
</phase>
</pnp>
<groupPolicy/>
</boot>
</results>
I managed to isolate the problem. Disabling "AuthenTec Fingerprint Service" created the delay. Re-enabling it removed the delay, regardless of what I did with the other services.
davehc
First question is why did you disable so many services? (Or do I misunderstand your statement). They have dependencies, which are essential to the effiicient and full operation of Windows 7. Without exception, in Windows 7 there is a different approach to loading material, in particular services. They do not consume too many resources now, but are, as it were, "waiting in the wings" for use. Some, admittedly, can be disabled, or put on manual, if yo have no use for them. Windows defender, for example, if you have a third party antvirus program. I have the Fax service disabled, as another example. I have attached my own setup, which has, for my use, the bear minimum disabled. But you might find this site interesting, but use it with caution. I think the autor fell behing a little with the introduction of Windows 7 technique.
But, to continue. A 5 second start was remarkable!! With respect, I think you may have misread something! Could you give a briief outline of your Computer config - CPU & Ram in particular. For the average computer, all software installed and configured, a 45 second start up from cold is reasonable.
JCook84
I think you may have misunderstood. The 5 seconds was after it reaches the login stage: in other words, after I type in my password and press return, it used to take less than 5 seconds to get me to the desktop. Now it takes more than 30. I'm NOT talking about the total startup time here.
Same goes with unlocking the computer. It used to take less than 5 seconds to unlock after I typed in my password.
I disabled some of the services because they came with the computer and I don't need them.
Then I tried to disable all of them to see if that would help anything.
JCook84
Oh. Wow.
Just to see what happened, I re-enabled every single service there was. (I'm talking about the non-Microsoft services that Toshiba bundled with the laptop.) And the problem went away.
So, I assume one of the non-Microsoft services I disabled actually was important. I'll go through and disable them one by one.
To be clear, I didn't disable any of the services that came with Windows 7 (except briefly to test out if that would help). The services I'm talking about are not part of Windows 7.
And thanks, davehc, for giving me the idea to re-enable everything. :)
JCook84
davehc
Great. But bear in mind the usefulness of the MS Services. (Good tip for other users, by the way)
