MattLoaf
Well-Known Member
Title says it all really. I have two USB hubs neither of which Windows can find a USB mouse on. I think the problem is that I have tried a number of USB mice on this machine so Windows does not know which driver to use. Any idea's?
(I'm using a laptop with three USB ports so I need to use a USB hub.)
***EDIT***
It's just in general, the USB hub has nothing to do with it now.
In Device Manger, try removing all of the USB Host Controllers and Root Hubs and let them be re-detected. This has worked for others.
***EDIT***
busydog
***EDIT***
