The forum thread discusses optimizing Windows Vista's network performance, with the original poster sharing various commands to tweak TCP settings for better throughput and response times, mainly focusing on adjusting receive window size, congestion providers, and other network parameters. A user inquires about improving P2P download speeds, prompting detailed advice on potential ISP and hardware limitations, NAT configuration, and bandwidth optimization. The overall sentiment emphasizes that while some tweaks can enhance network performance, factors like ISP restrictions and hardware compatibility play significant roles.
n9nu
I don't know if I mentioned these here in the past, but I will list them so you guys can see if it makes a difference for you as well. These commands should be implemented in the Administrators Command Prompt (Terminal) as the Administrator. These commnands pertain to throughput between computers (LAN) as well as to decreasing browser response / page load time.
I was experiencing poor performance between my FreeNAS box and this Vista SP1 machine for the longest time and finally realized I can tweak Vista's TCP Window Tuning despite it being "pre-set" for optimum performance. Your gain or loss will vary of course, but hey...what the heck...it's easy to switch between them. These commands will allow the Receive Window (RWIN) to dynamicaly change my manually setting it to expand by "x" factor. Option 1 below is "normal" or "autotuning on" which is the default for most Vista versions.
Despite Vista SP1, there are still some bottlenecks with regards to throughput and response time. I have SP2 installed and I still use the manual method #3 below with enhanced results. That is with a fresh slipstreamed install. Anyways....see what you come up with.
At the Adminitstators Command Prompt, enter one of the following options (1, 2, 3 or 4 )
1. netsh interface tcp global autotuninglevel=normal <---default setting for most Vista versions. 🙄
2. netsh interface tcp global autotuninglevel=highlyrestricted <---- allows RWIN to expand conservatively 😱
3. netsh interface tcp global autotuninglevel=restricted <----what I use ~ 40% increase in thoughput for me. Allows for greater RWIN expansion. 🙂
4. netsh interface tcp global autotuninglevel=disabled <---- Reported to increase thoughput when using P2P Networking and when using downloading agents (IDM, IDA, DAP, etc). 😕
5. netsh interface tcp global autotuninglevel=experimental <----- just what it says. Allows for extremely large, extremely high bandwidth connections (DS3 or >) - May decrease performance with lower connections. Not Recommended.
I created a small batch (.bat) file with a menu to switch between them so I could get a consitent benchmarks to my liking. You have to reboot your machine between each change.
The above commands won't screw up your system in anyway other than slowing or speeding up your file transfers / browser surfing sessions, so experiment. You might get lucky and notice a substantial INTRANET file transfer gain.
Below are some other settings that can have a substantial impact on performance. Most of these are pre-set to their optimized settings, so I will list those for information purposes.
CTCP (Compound TCP)
Traditional algorithims that are used to decrease or "handle" network congestion are not necessarily optimized to deal with the high-speed INET connections that are available to some of us today. Thus, CTCP can deal with these larger connections by closely monitoring delay times and packet loss to minimize congestion while increasing thoughput by handling the RWIN factor in a more aggressive way. This option in Server 2008 is turned ON. In Vista, it is OFF by default. Turning this ON could boost your performace substantially. This newer way of handling congestion by different algorithim methods has boosted my throughput on 2 of my machines alone. I suggest everyone try this one. This will work for all modern "broadband" connections. The bigger the pipe, the better.
From the Command Prompt, issue the following command(s):
netsh interface tcp set global congestionprovider=ctcp <---- Suggested setting.
netsh interface tcp set global congestionprovider=none <---- Default setting for Vista netsh interface tcp set global congestionprovider=default <---- restores system default
I have had great luck with this switch and I am sure some of you will also have good luck as well.
MTU (Maximum Transmission Unit) Default network value for Ethernet is 1500
Two words on changing the MTU in Vista. Don't bother. By default, Vista uses the maximum size for the basic network grid. The common misconception with this command is that by raising it to a higher value (e.g. 9014) you will allow for a larger packet Frame to be sent. Here is the truth. For day to day downloading, surfing, etc., 1500 is the sweet spot. There are some exceptions. Most notibly, peer to peer (direct PC to PC via NIC) connections. In ths case, the MTU can be raised and will allow for a higher rate. I have one of these connections from my FreeNAS server box and one of my Vista SP2 boxes. Other than a direct connection like that, raising the MTU will yeild you next to no increase in performance/thoughput. The most important option is the Receive Window (RWIN).
ECN (Explicit Congestion Notification)
This option allows for a different communication method to deal with network congestion. It dynamicaly lowers the transfer rate for certain "retry" packets thus preventing packet loss as much as possible. ECN is disabled in Vista by default and should remain that way UNLESS your router does not support ECN. All newer routers do...so only the very old ones could have a problem with this option be disabled and enabling it might be your best bet.
To check whether your router supports ECN, you can use the Microsoft Link Removed. The results will be displayed under "Traffic Congestion Test" in the detailed report.
Only if you need to change this option, do so by issuing the following command via the Command Prompt as follows:
netsh interface tcp set global ecncapability=enabled <---Only for those who's routers fail the ECN test from above. All other users (99% of us), may disregard this option. Period.
There are several others (RSS, TCP Chimney Offload, etc) that are available, but Vista has them set to their optimum values. For most part, the above material is about all you need to optimize your connection if you are having problems or want to squeeze more out of your connection and hardware. A TCP Analyizer will help when determining your max MTU if you need to setup a direct PC to PC static route.
The last option is for on-line gaming. The setting below WILL reduce latency (by 1/2 in some games) when disabled. This is only for a certain hand full of games. World Of Warcraft IS one that will take advantage of this. The Nagle Alrorithm can be disabled to allow for faster packet transfers by removing the delay times between transfers. This only works for very small packets..thus is perfect for online games. The downside is that it will most likely reduce thoughput overall. This should not be a big deal when playing games on-line as latency is much more important than a big pipe. I do not know which games, other than WOW, that take advantage of this, so I will not go into detail on how to modify the settings unless someone specifically requests it. This mod involves editing the registry and changing/adding about 3-4 options. You may PM me or request it via a Reply here.
I hope some of these commands help at least 1 person out there. It helped me and I have a 55-Mbit connection here...and I receive email from others that have benefited as well, so I know these work for some.
Tim
Digital Audio Productions
Hi. Although I personally do not use BT for that reason alone (speed), there are several things you can check and modify to improve your throughput. I only list all the possibilities below to use as a reference guide. I do not know your ISP, your knowledge of networking, etc, so I just listed everything in case you needed more info in general.
First things first. Is your ISP limiting (capping) P2P or BT traffic? Is your hardware router listed on the "bad routers" for P2P list? Follow the numbers below to start.
1 .Here is a list of ISP's that play nasty and can cause problems with using any kind of P2P client. Check this site to see if your ISP is listed: Link Removed
2. Here is a list of so called "bad routers" that...
Celestra
Former Moderator
How do I manually increase download speed for an avi. torrent (P2P) file using Vuse ? I have DSL, but on automatic I'm just average. (My carrier can handle faster downloads and uploads) A 36 hour download freaks me out!!!
n9nu
Thread Author #3
2. Here is a list of so called "bad routers" that do not handle P2P/BT services well: Link Removed Those pages are from the Vuse Wiki and I know for a fact that they are incomplete/outdated.
If you find out that your ISP is indeed limiting Peer to Peer (P2P, BT, etc), then your more or less screwed. Time for another ISP perhaps? If your router is a "problem one", then you can always purchase another model which isn't listed or (if it's a Linux based firmware router) re-flash the firmware with another code set (Tomato, DD-WRT, etc). Another good source of information on how to manually do things is their own forum in which they have the following dedicated section: "Support - Speed/Connection Problems". The link is: Link Removed - Invalid URL
3. This page seems to sum everything up by giving you suggested settings for your available bandwidth. Read through that for sure: Link Removed
The information below is just a more in depth reference to each of the hardware problems that many users have. There is also their own bandwidth/settings calculator you can use to obtain optimal settings. That is number 6 at the bottom.
4. The next page is also from their Wiki and pertains to NAT (network address translation) problems. If you have a hardware or software router, you can be sure it is most likely running NAT. If your PC(s) behind the router (ones that are plugged into the LAN ports) are using a private address such as 192.168.0.1 or 10.x.x.x, then it is running through NAT. Only the router itself has your "real" ISP assigned address. The link below will tell you how to diagnose and fix NAT problems with Vuse: Link Removed
5. The following will help you understand port forwarding which has to be enabled and setup with the Vuse ports they tell you it uses: Link Removed
6. The following link will take you to their Upload/Download speed calculator applet in which you plug in your ISP's Up and Download limits to calculate Vuse settings: Azureus upload settings calculator
Celestra
Former Moderator
Thank You Very Much..... There's a lot of information- I'm going to have to read carefully. Maybe this is still valid ? It is some technical data from my last download. I use "DSL Extreme"- not on the bad list. I have a D-Link Modem. Upload Limit is 308 KB/s (Estimate), Download Limit 294.5 KB's (Estimate)
