DonKeyKong
I was having a hell time with it so go 'adapter settings' then to 'Local Area Connection' IVP4 details and put in the ip address and gateway and DNS manually and turned off QoS Packet Sheduler! This worked for me and I have had no connection issues with it since. Good luck!
-Si
dre@ms
^^ thnx for sharing your solution, might be useful for some1 experiencing the same issue has yours.
