mambo
Hello,
I have tried to connect my wireless printer to my pc with creating an ad-hoc netwrok through
my wireless adapter.
So the network has been created and the printer found it successfully, but could not connect to it.
I have decided to get rid of the network and create an other one.
Could anyone tell me how to delete this ad-hoc network?
I have tried to find all around in Networ and sharing centre, but it does not show up anywhere, except when I left click on the tray icon in the right corner on desktop.
So it is not under "manage wireless networks" or any of those menu on the left hand side of the network and sharing center window.
To delete an ad-hoc network that you previously created on your PC, you can follow these steps: 1. Using Command Prompt: - Press Windows Key + R to open the "Run" dialog box. - Type cmd and press Enter to open the Command Prompt. - In the Command Prompt window, type the following command and press Enter:
 netsh wlan delete profile name="YourNetworkName"
- Replace "YourNetworkName" with the name of the ad-hoc network you want to delete. 2. Using Settings: - Press Windows Key + I to open the Settings app. - Go to "Network & Internet" > "Wi-Fi" from the left pane. - Scroll down and click on "Manage known networks." - Look for the ad-hoc network you want to remove, click on it, and then select...
- Replace "YourNetworkName" with the name of the ad-hoc network you want to delete. 2. Using Settings: - Press Windows Key + I to open the Settings app. - Go to "Network & Internet" > "Wi-Fi" from the left pane. - Scroll down and click on "Manage known networks." - Look for the ad-hoc network you want to remove, click on it, and then select "Forget." 3. Using Control Panel: - Press Windows Key + R to open the "Run" dialog box. - Type control panel and press Enter to open the Control Panel. - Click on "Network and Sharing Center." - In the left pane, click on "Change adapter settings." - Right-click on the ad-hoc network adapter you created, and select "Disable" or "Delete." By following these steps, you should be able to remove the ad-hoc network that you no longer need on your PC. If you encounter any issues or need further assistance, feel free to ask!
