The thread discusses the possibility of multiple users simultaneously interacting with a Windows Vista PC from a Mac. The original poster seeks a solution to allow one person to use the PC while another is actively logged in and working on it concurrently, which is different from file sharing or remote access solutions like TeamViewer. Several responses clarify that Windows desktop operating systems do not support multiple concurrent user sessions without licensing multiple user accounts or using Windows Server with Terminal Services, indicating that the scenario described by the original poster is not feasible on a standard Vista PC due to licensing and technical limitations.
Nope.But can 2 people use the PC at the same time? Both doing different things.
No Windows Desktop OS supports multiple Remote Desktop Connections simultaneously. That is to say, that the console session is surrendered when a remote destop session is initiated. For that you would need something running Terminal Services, which "legally" is only support on the Windows Server platforms.
Gavin Oscur
Well-Known Member
- Joined
- Apr 5, 2014
- Messages
- 78
I found one link regarding this issue and might it helps- Link Removed.
Gavin Oscur
Well-Known Member
- Joined
- Apr 5, 2014
- Messages
- 78
Sorry for not understanding your issue in right manner, this time I try to give a correct answer of your query as “How can I connect from Mac to vista PC” might it helps you- http://www.simplehelp.net/2008/07/0...ows-vista-using-remote-desktop-from-your-mac/
Trouble
Noob Whisperer
- Joined
- Nov 30, 2009
- Messages
- 13,723
I would suggest perhaps using something like TeamViewer installed on both machines.
I believe they have a version available for most Operating Systems.
http://www.teamviewer.com/en/index.aspx
Trouble
Noob Whisperer
- Joined
- Nov 30, 2009
- Messages
- 13,723
The discussion seems to be about three different levels of computing.But can 2 people use the PC at the same time? Both doing different things.
Badrobot's device basically shares computing power and perhaps shares access to files, but each user is essentially working on his own computer.
The next step up, is using the Mac to remotely log on as a user on the Vista PC at the same time another user is physically logged on to the Vista, and both use the Vista concurrently doing different things, independently and unaware of each others activity.
The third level Is something like TeamViewer that Trouble suggested--collaborative or interactive computing, where both users are aware of each others activity and share a common view, and each can do independent things in relation to the shared view.
Interesting that products exist to do 1 and 3 but the middle one, which sounds like buggs1a's objective, can't be done, essentially because of licensing issues?
