Mr Spangle
When copying files over a wireless network, between an XP laptop with a wireless g card and a Win 7 laptop with a wireless n card, will I notice any speed improvements by upgrading my current wireless g router to a wireless n router?
In other words, will the entire wireless n machine -> router -> wireless g machine pathway slow down to the speed of the slowest machine, or will the wireless n -> router leg of the journey keep its higher-speed potential?
Thanks in advance.
Yes, the 802.11n router to the 802.11n pc wil communiate at n speeds whilst the 802.11g pc will communicate at g speed. Even so, if you are sending a file form the g pc to the n pc the it simply means that the n connection will be idle waiting for the data - the total transmission time will not be improved.
patcooke
Microsoft MVP
Microsoft MVP
