The thread discusses a persistent WiFi connectivity problem where the user is seemingly connected but cannot access the internet, with initial troubleshooting steps including resetting network settings, updating drivers, flushing DNS, and adjusting adapter settings. Despite these efforts, disconnections continue, leading the helper to suggest more advanced diagnostics such as checking for interference, router issues, or faulty hardware, along with potential network configuration changes and contacting the ISP if needed. Overall, the conversation reflects a troubleshooting process with a cautious and detailed approach, emphasizing the complexity of resolving intermittent WiFi issues.
Ethanmiller
Does anyone know how to fix this? I’m seemingly connected to wifi but the sites I visit say there’s no internet.
An image from 'WiFi dropping connection every few minutes'. Browser shows 'This site can't be reached' error for panerabread.com due to timeout.
Hello, Your issue might be related to a variety of factors. Let's try to troubleshoot it step-by-step:
  • Reset Your Network:
  • Open the 'Settings' application (or press Windows Key+I)
  • Navigate to 'Network & Internet' > 'Status'
  • Scroll down and click on 'Network Reset' This will reinstall your network adapters and set your networking components back to their default settings. Your computer will restart after this process.
  • Update Network Adapter Drivers:
  • Right-click the Windows key and select 'Device Manager'
  • expand 'Network adapters'
  • right-click on the wifi adapter and select 'Update driver' If the problem persists after this, try downloading the latest drivers from the manufacturer's website...
  • Flush DNS and Reset TCP/IP: Sometimes this problem can be caused by DNS or IP settings. Try these commands to reset them:
  • Search Command Prompt in Start Menu, Right-click to run it as an administrator.
  • Type the following commands one by one and press Enter after each: ipconfig /release ipconfig /flushdns ipconfig /renew netsh int ip set dns netsh winsock reset
  • Restart your computer
  • Configure your wireless adapter settings:
  • Navigate to 'Network & Internet' > 'WiFi' > 'Hardware properties'
  • Write down the name and manufacturer of your adapter
  • Open the 'Power Options' from Control Panel
  • Find your power plan and click on 'Change plan settings'
  • Click on 'Change advanced power settings'
  • Locate your wireless adapter in the list and set it to 'Maximum Performance'
  • Change the WiFi channel: If you have a lot of devices connected to the same WiFi channel, it can cause problems with your connection. You need to login to your router's admin and set the WiFi channel to either 1, 6 or 11 as these are the least overlapping channels. Another good practice is to place your router in a central location in your home and keep it away from walls and metal objects, as these can interfere with your WiFi signal. If none of the above helps, your problem might be related to your router or internet service provider, so consider reaching out to them for assistance. Let us know if the issue remains, we are here to help.
Ethanmiller
Thread Author #3
Hello,
1. **Reset Your Network:**
- Open the 'Settings' application (or press Windows Key+I)
- Navigate to 'Network & Internet' > 'Status'
- Scroll down and click on 'Network Reset'
2. **Update Network Adapter Drivers:**
- Right-click the Windows key and select 'Device Manager'
- expand 'Network adapters'
- right-click on the wifi adapter and select 'Update driver'
3. **Flush DNS and Reset TCP/IP:**
- Search Command Prompt in Start Menu, Right-click to run it as an administrator.
- Type the following commands one by one and press Enter after each:
`ipconfig /release`
`ipconfig /flushdns`
`ipconfig /renew`
`netsh int ip set dns`
`netsh winsock reset`
- Restart your computer
4. **Configure your wireless adapter settings:**
- Navigate to 'Network & Internet' > 'WiFi' > 'Hardware properties'
- Write down the name and manufacturer of your adapter
- Open the 'Power Options' from Control Panel
- Find your power plan and click on 'Change plan settings'
- Click on 'Change advanced power settings'
- Locate your wireless adapter in the list and set it to 'Maximum Performance'
5. **Change the WiFi channel:**
That doesn’t work because I always have to disconnect just for it to sometimes work again.
It sounds like the issue you're facing might go deeper than the initial fixes I provided earlier. Since you mentioned that disconnecting and reconnecting seems to temporarily work, it could indicate:
Possible Underlying Issues:​
  1. Interference or Signal Issues:
    • Crowded WiFi Band: If you're on a busy 2.4 GHz frequency in a neighborhood with other routers, interference could frequently disrupt your connection.
    • Distance or Obstacles: Are you far from your router, or are there lots of walls/metal objects hindering the signal?
  2. Router Problems:
    • Overheating or Overloading: If your router is old or overworked, it might be struggling to maintain stable connections.
    • Firmware Issues: Outdated router firmware can cause odd connectivity problems.
  3. Device-Specific Issue:
    • Your WiFi adapter or network interface card (NIC) may be faulty, have outdated drivers, or be configured incorrectly.
  4. DHCP or IP Lease Expiration:
    • If your DHCP server (on the router) is reassigning IP addresses, it can cause frequent disruptions.
  5. ISP Service Drops:
    • As a last possibility, the actual problem might reside in your internet service provider having intermittent disruptions.
Advanced Steps to Fix:​
  1. Manually Set a Static IP:
    • Sometimes, DHCP reassignments can lead to your device being kicked off the network. Assigning a static IP to your computer can prevent this.
    • Go to your WiFi settings > Adapter Options > Right-click your network > Properties > IPv4 > Set your IP manually (use something like 192.168.1.150 with a gateway of 192.168.1.1 if that matches your router's IP range).
  2. Adjust Router Channel Width & Band Selection:
    • In your router’s admin dashboard:
      • Select 20 or 40 MHz for the 2.4 GHz band.
      • If using 5 GHz, try different channel settings or bandwidth limits to see if stability improves.
  3. Perform a Factory Reset of Your Router:
    • If the router has retained corrupted settings, performing a reset and reconfiguring it might help eliminate glitches.
  4. Replace or Upgrade Router/Adapter:
    • If the router is more than 4-5 years old and you're still facing issues despite attempts to fix it, consider upgrading to a dual-band or tri-band model.
    • Similarly, test your computer with a different external USB WiFi adapter to see if the built-in NIC is causing problems.
  5. Run a Ping Test:
    • Open Command Prompt and type: ping -t 8.8.8.8 to monitor connection quality over time. If there are widespread packet losses, this indicates instability either from the router, your connection to it, or the ISP.
As a Temporary Measure:​
Since disconnecting works sometimes, you can turn off "Power Management" for your WiFi adapter:
  • Go to Device Manager > Network Adapters > Right-click your WiFi adapter > Properties > Power Management tab > Uncheck "Allow the computer to turn off this device to save power."
Reach Out to ISP:​
If none of the above resolves the issue and the ping test reveals consistent packet loss, contact your ISP with the test results and ask them to investigate for any service-related disruptions or equipment issues.
Keep me updated on what you try next—if none of these solve it, there might be a deeper issue to explore! 📡💻
