The thread discusses a user experiencing an issue with their Windows 10 PC where the Wi-Fi network list is hidden or not displaying in the system tray. Several contributors suggest troubleshooting steps, including checking hardware switches, network settings, and device drivers, while others recommend posting detailed device information or configuring network settings. Overall, the discussion aims to help the user recover or reveal their Wi-Fi network list, with advice varying from physical hardware checks to software configurations.
Please provide make/model of your computer. Is it a desktop PC or laptop/tablet? Is it a self-built PC you built yourself? Or an OEM computer (Dell, Acer, HP, Toshiba)?
Laptops still come with a Wi-Fi switch, which often gets turned off if you remove it from your home and travel with it somewhere. The process of putting the laptop into a carrying case and then taking it out again multiple times can easily move the switch to the off position where you will disable your laptop's Wi-Fi and thus won't get any list of Wi-Fi networks to popup on your windows screen to connect to! Here's an example of what that switch looks like:
Other laptops, most modern ones have done away with that physical switch and use a keyboard combo...
- Joined
- Aug 28, 2007
- Messages
- 36,163
Hi,Hi, when i click to open the available wifi networks there is no list shown in system tray. I have windows 10
Sent from my Hol-U19 using Tapatalk
have you tried rebooting the machine?
Did you install anything new recently, drivers, software or hardware?
Can you right click on the start menu icon and from the revealed list choose Device manager. See if any yellow question marks are there particularly where the wifi/network component should be.
Check your wifi router (if you have one) and if need be restart/troubleshoot.
- Joined
- Aug 28, 2007
- Messages
- 36,163
Morning Kay5ive,
Does this mean:
Let us know anyway.. 🙂
Does this mean:
You mistakenly hid the network wifi list and have since found it?Actually, there is some commands mistakenly clicked by me and wifi available network(list) hide.
- Joined
- Jan 28, 2013
- Messages
- 2,423
Other laptops, most modern ones have done away with that physical switch and use a keyboard combo of 2 or more keys to enable/disable the wi-fi radio inside of your laptop as pictured here:
Enabling your Wi-Fi switch by sliding a physical switch or using a combo keystroke will usually solve this problem.
If it doesn't, then you may have anything from a failed driver from a recent Microsoft or other update on your computer, to a failed hard drive. If you get to this point, you should consider testing your hardware. You can use this free TROUBLESHOOTING GUIDE I wrote to help you available here:
Windows 10 - Unclickable Task Bar
Let us know how you get on.
Best of luck,
<<<<BIGBEARJEDI>>>>
If it doesn't, then you may have anything from a failed driver from a recent Microsoft or other update on your computer, to a failed hard drive. If you get to this point, you should consider testing your hardware. You can use this free TROUBLESHOOTING GUIDE I wrote to help you available here:Windows 10 - Unclickable Task Bar
Best of luck,
<<<<BIGBEARJEDI>>>>
pnamajck
Honorable Member
- Joined
- Aug 28, 2014
- Messages
- 433
welcome to windowsforum, kay5ive … you might also review your wi-fi settings in w10 pc-settings:
you may also consider posting screen-cap if your issue has not been resolved by our efforts, kay5ive. another suggestion would be to post your question directly to the forum of your laptop manufacturer … the forum for toshiba is forums.toshiba.com … thanks.
- pc-settings / network-internet / wi-fi
- here you can choose to enable/disable wi-fi
- if desirable, click "show available networks"
- once this happens, an interface appears (above system-tray) …
- here, you can click "wi-fi" to view all connections (within your proximity).
When you click the network icon lower right in task tray you see a choice to turn WiFi on. If connected by Ethernet but all other devices are connected by WiFi via the router, they should be visible. Did you mistakenly click the off switch on the keyboard.?
Are you phones getting online visa WiFi which would mean you have a secure network.
Did you just change your password and need to click "forget" to 'view' your SSID?
Good luck.
Good luck.
