The Surface Pro Printing Experience: Why Is It So Frustrating?
Printing should be a seamless operation, yet many users report persistent issues such as printers not appearing, jobs stalled in queues, wireless printers showing as offline, or even error messages unique to specific programs like Word, Excel, or OneNote. The diverse nature of these problems suggests there is no single culprit—but rather a confluence of driver compatibility issues, Windows update glitches, network configuration faults, and occasional Microsoft Office quirks.
Typical User Complaints
- Printers always offline on Surface Pro while working for other computers
- Network drives and printers not visible or accessible
- Print dialog only offering OneNote as a destination
- Wireless printing broken after updates
- Printing from Office apps fails but PDFs print fine
- CTRL+P and print commands do nothing in browsers
- Ink gets sent to queue but does not print, or prints very slowly
These issues are not hypothetical but drawn from real user experiences across multiple generations of the Surface Pro line.
Understanding the Surface Pro and Windows Printing Stack
The Surface Pro, while running a "full" Windows experience capable of using legacy desktop applications, also incorporates layers of modern security, virtualization, and touch optimization that can complicate direct hardware access needed for printing. Windows 10, 11, and now 12 have each introduced their own evolutions in print management. The notorious retirement of legacy printer drivers, increased reliance on Windows Update for device setup, and tighter sandboxing of apps all play a role.
Key Contributing Factors
1. Driver Compatibility and Automatic Updates
Surface Pro devices, because of their cutting-edge hardware profile, often rely on the newest drivers provided through Windows Update. For printers, this can result in:
- Windows automatically installing generic or incorrect drivers
- Legacy or manufacturer-specific features lost with universal driver
- Older printer models never receiving updated drivers for the latest Windows versions
For example, users printing to popular brands like Kyocera or HP have found that after upgrading to newer Windows versions, office documents no longer print while PDF and graphics jobs work fine, due to hidden driver errors such as “PCL XL error” or “IllegalGlobalTrueTypeSegment”. In such cases, manufacturer support may lag behind Surface and Windows release cycles.
2. Network Discovery and Firewall Challenges
Many printers are shared over Wi-Fi or local networks. Several Surface Pro owners report that while other PCs see the printer or network drives, their Surface shows an empty “Network” folder or marks the printer “offline”—often despite successful wireless connection to the router.
This behavior is frequently traced to:
- Network discovery or file and printer sharing being disabled
- Overly restrictive Windows Firewall rules
- Drivers not installed for networked printers, only for direct USB use
- Surface’s defaulting to “Public” rather than “Private” network profiles (which limit sharing)
One classic workaround involves uninstalling/reinstalling network adapters or re-enabling discovery, but often this needs to be repeated after major updates or resets.
3. Default Printer Confusion
After installing Office, some users find that the only print option is “OneNote,” or jobs default to virtual printers (e.g., Microsoft XPS Document Writer, PDF printers). Printed jobs never reach the physical printer. This occurs when Windows forcibly assigns a digital-only printer as the default, often after updates or Office reinstalls.
4. Browser and App Paradigm Shifts
Windows Store (UWP) apps and some newer browsers run in sandboxed environments that may not have direct printer access. Users attempting to print from such apps may receive error messages like “you can only print from an app” or discover print dialogs missing the printer entirely. Some browsers, notably Firefox during the Windows 8/8.1 era but also in later Windows builds, fail to trigger the expected print dialog, while legacy apps like Notepad print fine.
5. Corrupted Print Spooler or System Updates
Printing is dependent on the Windows Print Spooler service. Corruption—whether from failed updates, malware, or software install mishaps—can prevent Surface devices from printing at all, with jobs getting stuck in the queue, or the Spooler service failing to start. Sometimes, only a thorough reset, cleanup, or use of specialized repair software will restore functionality.
6. Office Add-Ins and Compatibility
Specific issues with printing from Office applications are often caused by third-party add-ins (such as PDF creators or anti-virus integrations) which interfere with the print process. Disabling or removing these add-ins often resolves the issue.
Troubleshooting: Step-by-Step Guide
While each Surface Pro printing issue has its nuances, the following checklist covers the overwhelming majority of cases:
1. Check Printer Compatibility and Drivers
- Visit the printer manufacturer’s support site.
- Download the latest Windows 10/11/12-specific driver (not the universal or generic version).
- During install, right-click and set compatibility mode to Windows 7 or 8 if needed (for older printers).
- For network printers, ensure you select the correct network installation option—not just USB.
Caution: Some printers, especially legacy models, may no longer receive driver updates compatible with the newest Surface Pro or Windows version. In these cases, generic drivers may limit features or break functionality.
2. Verify Network Settings and Sharing
- Ensure the Surface Pro is connected to the intended network and set to “Private.”
- Open Settings > Network & Internet > Status > Sharing Options.
- Enable “Turn on network discovery” and “File and printer sharing.”
- Temporary: Disable Windows Firewall to test (restore after testing).
If still unsuccessful, open Device Manager, uninstall the Wi-Fi and networking adapters, then “Scan for hardware changes.” This can force the Surface to refresh its network connections and sometimes brings printers back online.
3. Set the Correct Default Printer
- Go to Settings > Devices > Printers & scanners.
- Ensure your physical printer is marked as “Default.”
- If “Let Windows manage my default printer” is enabled, turn it off to prevent unwanted changes after each new device or location.
If “Send to OneNote” or “PDF” shows as the only target, remove or set a different default to allow direct printing.
4. Test Printing from Multiple Apps
- Try printing from basic applications like Notepad or WordPad.
- Attempt from both classic desktop apps and Microsoft Edge or Chrome browsers.
- If an app-specific problem arises (e.g. only Office fails), consider disabling non-essential add-ins.
5. Restart Print Spooler Service
- Type “services.msc” in Start menu.
- Find “Print Spooler,” right-click, and select “Restart.”
- If the service cannot be started, or errors persist, run a full spooler cleanup: delete all files from C:\Windows\System32\spool\PRINTERS.
Specialized “print spooler fix” tools are available but should be downloaded only from reputable vendors due to the risk of malware.
6. Run Windows Troubleshooter
- Navigate to Settings > Update & Security > Troubleshoot > Additional troubleshooters > Printer.
- Follow the prompts. Note: This built-in tool solves only common faults; complex driver or network issues may persist.
7. Firmware and System Updates
- Check for both Surface firmware updates and Windows updates.
- Out-of-date Surface firmware has been linked to network printing glitches, especially after feature releases or cumulative updates.
Warning: Occasionally, Windows Updates themselves cause breaks in printing. If so, check forums for the specific update build and known issues, and consider rolling back to a previous state if the problem coincided exactly with the update.
8. Advanced: Reset or Reinstall Printing System
- Delete the printer in “Printers & Scanners.”
- Remove related software via “Add or Remove Programs.”
- Reboot Surface before reinstalling the latest driver package.
9. Try USB Instead of Wireless (if available)
- Connect via cable to determine if the problem is network-related or device-specific.
10. Consult Manufacturer and Microsoft Support
If the issue remains unresolved after all basic steps, the cause is likely a deep compatibility fault or system corruption, requiring professional assistance.
Office-Specific Printing Glitches
A recurring problem for some Surface Pro users: printing from Word, Excel, or OneNote demands routing jobs through OneNote, or print options are missing. This can be infuriating, especially for those purchasing new Microsoft Office subscriptions alongside their Surface Pro.
Resolution Tactics:
- In Office, check File > Print and confirm that your actual printer is selected, not “Send to OneNote.”
- Remove or disable unnecessary virtual printers.
- If Office blocks printing to real printers while fine with OneNote or PDF, consider a complete Office repair or reinstall.
Add-ins, particularly those from PDF or anti-virus suites, can sabotage Office’s printer detection; disabling them may fix the problem.
Broader Implications and Trends
The Shift to Cloud and Paperless Solutions
Microsoft, like many tech giants, has steadily nudged users toward a paperless workflow. With the Surface Pro and its inking capabilities, many users now mark up PDFs, sign contracts, and review documents digitally, reducing demand for printed copies.
For some, this is liberating—fewer wires, less waste, and immediate access to documents from anywhere. For others, especially those bound by regulatory or workflow demands, reliable printing remains non-negotiable.
Strengths of the Surface’s Modern Printing Approach:
- Quick installation via Windows Update.
- Integration with “cloud printers” (e.g. Microsoft Universal Print).
- Seamless inking and markup for digital document flows.
Risks and Weaknesses:
- Legacy device and driver support is waning.
- Major updates can silently break print capability.
- Advanced printer features, popular in business setups, may be lost or require complex workarounds.
- Heavy dependence on an always-active internet connection can disrupt driver downloads and network printer access.
Surface Pro in Professional and Educational Settings
Some institutions have embraced the Surface ecosystem fully, relying on cloud-managed device policies (through Intune and Azure AD) and Office 365 integration for printing services. These setups, though more reliable, demand a modern infrastructure and may leave small businesses or home offices behind if their existing printers are not fully supported.
Future-Proofing Your Printing Workflow
As Microsoft continues its march toward cloud-first, hardware-agnostic workflows, users of the Surface Pro and similar devices must plan ahead:
- Before Buying a Printer: Check for explicit support for your specific Surface Pro and Windows build. Models with manufacturer-certified “Windows 10/11/12” drivers fare best.
- Stay Informed: Subscribe to both Windows and your printer manufacturer’s support alerts—major updates often coincide with printing issues.
- Embrace Digital First: Where possible, shift to workflows that leverage inking, annotation, and saving rather than printing.
- Understand Cloud Printing: Investigate Universal Print or similar services if you rely on document access across multiple devices and locations.
- Maintain Backups: For mission-critical print tasks, maintain access to a secondary printing device or even an old-fashioned USB stick to transfer jobs in extreme cases.
Conclusion: Solving the Surface Printing Puzzle
The inability to print from a Surface Pro is rarely the fault of the device alone. Instead, it results from a delicate interplay between rapidly evolving Windows software, a sprawling universe of printer hardware and drivers, and new security and network paradigms. By methodically working through compatibility, network, and software checks—and resetting expectations where possible—most users can restore reliable printing.
Yet until Microsoft and hardware vendors deliver a truly seamless and universal solution, printing will remain for many Surface Pro owners an ongoing dance between frustration and fix. Staying up to date, proactively managing drivers and defaults, and making full use of digital workflows are the best defenses against future headaches.
For those stuck with stubborn printing issues, persistence—alongside a strong network connection and a little technical patience—is still the surest way to keep your Surface Pro working for you, paper and all.
