SavorySilicon
- Joined
- Jan 28, 2020
- Messages
- 120
Windows 11, Backupper 7.3.2 Pro. Created 7 text files, did an encrypted file backup with BU, then changed file extension .AFI to .TXT, and half of the files were encrypted, half of them were not.
1) Text file.txt created, with 1 word "Kitty".
2) Backupper file backup with encryption enabled.
3) .AFI image created, copied, converted to .txt file
4) Windows Notepad easily displays content of backup in plaintext unencrypted form.
4b) An example of another file backup with encryption that did not work:
www.ubackup.com
Could you please test this program's encryption, and post your results? Thank you.
Backup Image Encryption in AOMEI Backupper
The option of image file encryption can help to encrypt the image file by setting a password so as to protect the data from unauthorized access.
