karl Phillips
My questions is this:
Anyone out there have a dual boot setup with 32 and 64 bit operating systems?
I am curently running 32bit XP, Vista, and 7 on my machine. I would like to remove the 32bit version of 7 and replace it with the 64bit version as I assume it's not possible to have 32 and 64 bit Windows 7 on the same machine. I am setup for 64bit and I'm just looking for a little guidance in the install process..
Thanks
Karl
hammydown
just put inthe 64 bit disc and install directly over the 32 bit version of windows 7. You should have no problems.
pbcopter
I am multibooting Vista Ultimate 64, Windows 7 32bit and Windows 7 64 bit with no problems.
