The original poster experienced issues with USB devices not working during a Windows 7 installation despite BIOS settings, which was resolved by enabling the PS/2 emulator in BIOS. However, after fixing this, they encountered a new problem preventing Windows from installing on a specific partition of disk 0. The thread primarily focuses on troubleshooting hardware compatibility during installation, with the user seeking advice on how to resolve the partition-specific installation error.
redwoz
I have a G19 and a mouse. And both of these wont work when i try to do a installation of Windows 7. It will get up to the first dialog screen but i cant go any further due to the devices not working. In the bios the USB legacy is enabled. and the mouse also works in the bios.
This the MB i have. https://www.asrock.com/MB/Intel/Fatal1ty Z270 Gaming K6/index.asp
Anyone with suggestions i should try. Thanks.
redwoz
Thread Author #2
I have resolved the problem with the mouse and keyboard through the Bios i found PS/2 emulator which solve the problem. But now i have another problem.
When i try to install windows on disk 0 partition 4 windows cannot be installed on drive 0 partition 4. How do i fix this?
