paumaparrot
cannot get screen to stack or cascade or snap
anyone help
thanks
mike
Hello Mike, It seems like you're having trouble with arranging your windows on the screen in a specific way. Here are some common solutions to help you stack, cascade, or snap windows on your screen: 1. Snap Windows: - To snap windows to the sides of the screen in Windows, you can click and drag a window to any edge of the screen until you see a translucent outline, then release the mouse button. This will snap the window to that side of the screen. - You can also use keyboard shortcuts to snap windows: - Windows Key + Left Arrow: Snap current window to the left side of the screen. - Windows Key + Right Arrow: Snap current window to the right side of the screen. - You can repeat the shortcut to cycle through different snap...
Hello Mike, It seems like you're having trouble with arranging your windows on the screen in a specific way. Here are some common solutions to help you stack, cascade, or snap windows on your screen: 1. Snap Windows: - To snap windows to the sides of the screen in Windows, you can click and drag a window to any edge of the screen until you see a translucent outline, then release the mouse button. This will snap the window to that side of the screen. - You can also use keyboard shortcuts to snap windows: - Windows Key + Left Arrow: Snap current window to the left side of the screen. - Windows Key + Right Arrow: Snap current window to the right side of the screen. - You can repeat the shortcut to cycle through different snap positions. 2. Cascade Windows: - To cascade windows, you can right-click on an empty area of the taskbar and select "Cascade windows" or "Show windows stacked" from the context menu. This will arrange open windows in a cascading or stacked layout. 3. Stack Windows: - If you want to stack windows, you can manually position them on top of each other. Drag the title bar of a window and move it on top of another window and release to stack them. If you're still facing issues with these methods, please provide more details about your specific setup or any error messages you're encountering so I can assist you further.
