The thread discusses a recurring issue where the user's desktop background automatically switches from "fit" to "fill" after a few minutes, prompting frustration. The original poster seeks help, and responders suggest checking theme and screen saver settings, including ensuring no active screen savers and deleting unsaved themes. Overall, the troubleshooting indicates a focus on display and theme options, with the conclusion leaning toward removing unsaved themes as a potential fix.
The only other thing I can think of at the moment, would be to remove/delete any unsaved themes. Make sure you have the themes/background images you are deleting, saved in another location for future use if desired.
Regards
Don
Regards
Don
Adamsappleone
U.S.Navy D.A.V.
- Joined
- Aug 2, 2009
- Messages
- 1,642
Hello Hickia and Link Removed to windowsForum;
Try going to "Appearance and Personalization/Change the Theme" and click on the background image, then click save, to save it, at that point you can also name it.
Keep us posted
Don
Keep us posted
Don
Hmm but my themes are already saved. It then automatically changes to an "unsaved theme".Hello Hickia and Link Removed to windowsForum;
Keep us posted
Don
Adamsappleone
U.S.Navy D.A.V.
- Joined
- Aug 2, 2009
- Messages
- 1,642
Strange, ok, try it this way, open "Control Panel" and click on "Appearance/Personalization", then under "Personalization" click on "Change screen saver", when that windows opens make sure "None" is shown in the drop down box.
See if that helps
Don
See if that helps
Don
Oh, when I opened it, it was already "none"Strange, ok, try it this way, open "Control Panel" and click on "Appearance/Personalization", then under "Personalization" click on "Change screen saver", when that windows opens make sure "None" is shown in the drop down box.
See if that helps
Don
Teemocaptain
Member
- Joined
- Aug 6, 2013
- Messages
- 42
But you maybe set the "Time interval", check it.Oh, when I opened it, it was already "none"
Adamsappleone
U.S.Navy D.A.V.
- Joined
- Aug 2, 2009
- Messages
- 1,642
Regards
Don
Regards
Don
