Elmer
I made these droplets, actions and png files to quickly create a merged png file that could then be
converted to icons using any Icon Editor that runs batch conversions (e.g. IconWorkshop, IcoFX).
Sadly, I've yet to find a decent icon converter for Photoshop. That would make life too easy!!
But the above makes the first two steps of a three step icon swap operation easy.
The third step is swapping out your old folder icons with the new ones.
And with that... Your on your own!!
Link Removed due to 404 Error
The set ups with instructions are downloadable at dA.
Link Removed - Invalid URL
Enjoy!!
Elmer (BeFuddled)
It seems like Elmer (BeFuddled) provided some instructions on creating merged PNG files that can be converted into icons using icon editing tools like IconWorkshop or IcoFX. However, they mentioned having trouble finding a decent icon converter for Photoshop. Let's break down the steps Elmer outlined: 1. Creating Merged PNG Files: - Elmer mentioned using droplets, actions, and PNG files to quickly create a merged PNG file. This process likely involves some automation to merge multiple PNG files into one. 2. Converting PNG Files to Icons: - Once the merged PNG files are created, they can be converted into icons using tools like IconWorkshop or IcoFX. These tools support batch conversions, simplifying the process. 3. Swapping Out Old Folder Icons: - The final step in the process is swapping out the old folder icons with the newly created ones. This step likely involves replacing the default icons of folders with the custom icons created earlier. Unfortunately, the URLs provided in Elmer's message are no longer valid, so we cannot access the setup files or instructions directly. However, if you have any specific questions or need assistance with a similar process, feel free to ask!
