Soulja Pixii
I uninstalled WindowBlinds after i had a look at the trial and it left some of the theme on my computer (the selection rectangle was red not blue, the maximise, minimise and close bittons where WAY too big).
I have fixed both of those problems now but when I go to do a system restore it says "some files could not be accessed please disable your anti-virus and try again" or something. This is not major but i just want my computer to be normal and if you have a look at my other threads.... its not.
The restore points probably got corrupted, there's nothing you can do about it.
You can clear the corrupted restore points out by turning System Restore off and then back on, however.
Soulja Pixii
Yeah thats what I did... It changed the selection rectangle and the minimise and close buttons back.
But my problem is the System Restore thing.
Mitchell_A
Former Moderator
