brkkab
I'm currently in the process of getting parts for a new computer build.
So far I have a Asus Maximus VIII Hero mobo and a Samsung 850 EVO 500GB. M/2 ssd for it. I'm also going to be re-using the Seagate Barracuda 3.0TB h.d , Intel 530 Series 400GB ssd (for Games), Lite On DVD-RW, Lite ON Blu-ray burner and memory card reader from my current pc.
I'm also going to be getting a NZXT Phantom 820 case. G-Skill Ripjaws-Z DDR 4 3200 ram (32GBS) and a Corsair HX-1000i psu for the new pc.
I need suggestions between the following part's for the new pc.
The heatsink is either going to be a EK-XLC Predator 240 or a Corsair Hydro Series H-100i GTX.
With either one, I'll be using 4 EK-Furious Vardar FF5-120 (3000rpm) fans in push/pull.
I also need help deciding between 2 GeForce GTX 4.0GB or 2 AMD Radeon 390X 4.0GB video cards.
I'm ordering a Intel Core i5 6600K cpu on Thursday and eventually plan on upgrading it to a Core i7 6700K in early 2017.
Keep in mind, I'm on permanent disability (Social Security) for life and can't afford to spend over $300.00 on a part/s in a month.
The pc won't be built until May as I won't have all parts until then minus the new video cards.
I'll be using my current GeForce GTX 760's until then, but they need to go back inn this pc, so I can sell it.
All suggestions appreciated between the AIO's and video card's.
P.S. PC will be running Windows 10 Pro x64.
I'm actually hoping for Tuesday or Wednesday. I have medical stuff Monday & Thursday.
Though, when I ordered my current pc's case, I received it the next day on a Saturday morning.
I very well may be building it tomorrow. I'll know sometime tonight when my tracking number is updated by FedEx.
I already have the number, they're just not as good as UPS or the USPS, in the tracking department. It probably won't give me any results until 11:00 P.M.
brkkab
I just installed the Windows 10 Anniversary update through a post here on the forums. Now, I'm just getting used to the changes in it. For instance if you want to shutdown or restart your pc, you now have to right-click on the start menu to get to it now. Also, you'll probably have to reinstall your video card drivers. I had to in order to get SLI working again.
Sonny
Fantastic Member
Hi brkkab, if you bring up your menu you will see the power icon over on the left of the menu. It is not in the main menu anymore. You also have the icon for setting there too or you can right click like you said to do it.
brkkab
Thanks Sonny, I just saw it. It's in the menu, if you right-click on the Start Menu's icon, too.
brkkab
I double-checked and all my Group Policy tweaks remained intact. I had to redo my registry tweaks though.
brkkab
I'm gonna be doing a clean install of Windows 10 Anniversary next Saturday. I'm just waiting for Microsoft to make it so their Media Creation Tool can get the Anniversary Update iso. Rufus freezes up at 95% making a bootable flash drive with the Anniversary Update iso I downloaded. I had to right-click on the iso and mount it to install it yesterday.
I lost 2 features that I had, so I need to do a clean install to get them back.
I lost the Windows Games and Windows Media Center, I had installed and working in Windows 10.
Plus, I'm upgrading Cyberlink Media Suite 12 Ultra to Cyberlink Media Suite 14 Ultra on Wednesday.
I'd rather do a clean install of that, too.
nmsuk
The rufus freezing up is weird. I used the latest version and tested with all the images Mike shared and it works fine. Bad download possibly?
brkkab
I'm pretty sure I ruled that out. I redownloaded the current version of Rufus and got the same exact result. I heard Microsoft will be posting the Windows 10 Anniversary Update iso's on Tuesday, too.
I'll just let the Microsoft Media Creation Tool download it and make my flash drive in the process.
From what I've noticed in the Anniversary Update, I don't see how it's going to be good if you have touch or a smartphone.Those icons on the left of the Start Menu are too small for my small fingers.
brkkab
I finally got Rufus to work. I did a clean install of Windows 10 Anniversary on Monday.
I upgraded my Cyberlink Media Suite 14 Ultra this morning.
There are some things I found that no longer work in the Anniversary update. The old Windows Games (FreeCell, MineSweeper, Solitaire, Spider Solitaire, etc. won't run.
3D Pinball and the Microsoft Internet Games will run.
I got Windows Media Center installed & working (minus tv stuff). I didn't install my tv tuner, as I know tv no longer works in WMC.
Now, I have to renew my Carbonite, go to the bank and take Sebastian to get his leg x-ray at the veterninarians office.
brkkab
I did a clean install of a Windows 10 Pro iso I made with Microsoft's Media Creation Tool. My download of the iso from the post here on the forum turned out to be buggy.
Now my pc is working great after the clean install. Now I just need to add my about:config tweaks to Firefox and let Cyberlink MediaShow 6 scan and add my pictures/videos to it, then I'm done.
brkkab
I just sped up my ssd's and hard drive with Asus RAMCache and RAMDisk. Capture is my Samsung 850 EVO 500GB M.2 ssd, capture 1 is my Intel SSD and capture 2 is my hard drive.
Huge improvement on all 3.
brkkab
According to speedtest.net I'm getting 116.** mbps for downloads and 11.**mbps for uploads.
brkkab
kemical: Did you check out my ssd speeds after using RAMCache & RAMDrive ? Both my slow Intel ssd and my Samsung are getting 11,*** reads. The Samsung is getting 11,*** writes and the Intel's getting 511 writes.
The Anniversary update repeatedly says Samsung Magician is unsigned @startup. I've got the current version. It must be another Anniversary Update bug..
brkkab
WillyBo: Thanks. I may have to check & see if Samsung sell a 850 EVO 500GB PCIe version. If they do, I may get one to RAID it with my 850 EVO 500GB M.2.
That would be early next year, though.
brkkab
I'm going to get one of these ROG logos for the door over my optical drives in my cases front panel. I'll probably order it when I order the red led case fans. Link Removed
