The thread revolves around a user planning a new high-performance PC build, seeking advice on components such as CPU, cooling solutions, and graphics cards while managing a tight budget. Other users suggest alternatives, like choosing a cheaper CPU like the i3, and share experiences with cooling systems and hardware choices, with some emphasizing cost savings and others commenting on the specific components' performance. Overall, the thread reflects careful planning and community support for building a customized PC suited to the user's needs and financial constraints, amidst some personal health challenges shared by the original poster.
brkkab
I'm currently in the process of getting parts for a new computer build.
So far I have a Asus Maximus VIII Hero mobo and a Samsung 850 EVO 500GB. M/2 ssd for it. I'm also going to be re-using the Seagate Barracuda 3.0TB h.d , Intel 530 Series 400GB ssd (for Games), Lite On DVD-RW, Lite ON Blu-ray burner and memory card reader from my current pc.
I'm also going to be getting a NZXT Phantom 820 case. G-Skill Ripjaws-Z DDR 4 3200 ram (32GBS) and a Corsair HX-1000i psu for the new pc.
I need suggestions between the following part's for the new pc.
The heatsink is either going to be a EK-XLC Predator 240 or a Corsair Hydro Series H-100i GTX.
With either one, I'll be using 4 EK-Furious Vardar FF5-120 (3000rpm) fans in push/pull.
I also need help deciding between 2 GeForce GTX 4.0GB or 2 AMD Radeon 390X 4.0GB video cards.
I'm ordering a Intel Core i5 6600K cpu on Thursday and eventually plan on upgrading it to a Core i7 6700K in early 2017.
Keep in mind, I'm on permanent disability (Social Security) for life and can't afford to spend over $300.00 on a part/s in a month.
The pc won't be built until May as I won't have all parts until then minus the new video cards.
I'll be using my current GeForce GTX 760's until then, but they need to go back inn this pc, so I can sell it.
All suggestions appreciated between the AIO's and video card's.
P.S. PC will be running Windows 10 Pro x64.
I'm actually hoping for Tuesday or Wednesday. I have medical stuff Monday & Thursday.
Though, when I ordered my current pc's case, I received it the next day on a Saturday morning.
I very well may be building it tomorrow. I'll know sometime tonight when my tracking number is updated by FedEx.
I already have the number, they're just not as good as UPS or the USPS, in the tracking department. It probably won't give me any results until 11:00 P.M.
I prefer plenty of airflow with a slightly positive air pressure (less dusty). If any hot air isn't expelled then it simply drifts out the top of the case.
Jimbo22
Here is a friend of mine doing just that ... some time ago ;)
I use one myself....after the initial leaf blower cleaning....I then crank up my air compressor and use the air nozzle to really clean out all the hidden places, ports/slots and heat sinks.
Jimbo22
Excellent just what I need. Now I wonder positive or negative air pressure, thoughts gentlemen?
I ran a air flow/heat temp bench test on my setup, running all 3 types; positive, negative and neutral....I get the best temps with negative air pressure/flow. To my surprise, it was a 4° difference between positive and negative....pretty significant in my book.
My case has 3 x 200 mm fans and 1 x 140 mm fan. 1 x 200 mm fan is in the front bezel; intake and 2 x 200 mm fans in the top bezel; exhaust and the 140 mm fan rear of case; exhaust. Then my Hyper 212 Evo cooling my CPU and that's pointing/air flow towards the 140 mm fan.
You might want to run some similar tests on your build.
brkkab
Thread Author #704
Mines probably somewhere like 60% intake and 40% exhaust fan wise.
Cooling setup:
Intake:
Front of lower case : 200mm.
Side Panel: 200mm.
Front Bottom of case: 2 140mm.
Pivot fan: Near front of top video card 140mm
Exhaust:
Rear of case: 140mm.
Top of case 4 120mm. on Arctic Liquid Freezer 240 push/pull exhaust.
brkkab
Thread Author #706
bassfisher6522: What's the name of the benchmark or it's link ?
nmsuk
Cooling setup:
Intake:
Side Panel: 200mm.
Exhaust:
I'm running 2 front 120mm 1 bottom 120mm 2 top rear in push pull for my radiator into the case and 1 top 120mm pulling hot air from the case. Cpu idle 19-30 full load under 50c and almost silent.
Jimbo22
There's no link or program/software.....I did it myself. Scientifically, set up air pressure configuration for each type, ran the system at idle for 30 minutes, then full load for 30 minutes....took notes and recored the system temps, powered down for 1 hour. Then repeated process for each air pressure configuration. Took a whole day to do it.
nmsuk
Not having a leaf blower, I shall be sticking to cans of compressed air and then isopropyl to clean the board and coolers. Which reminds me I need to re order some and get myself some arctic silver ceramique paste
brkkab
Thread Author #712
I may be getting a new 3.0TB h.d.d. from Seagate. Apparently my current one has disappearing issues and it failed SeaTools short self test earlier.
It's been disappearing while the Photos app is open and Cyberlink MediaShow 6.
It's been doing it with those 2 for about a month now.
Then this morning the hdd disappeared while Bitdefender Internet Security 2016 was running it's scheduled daily full scan and later on it disappeared while I had Chrome open.
brkkab
Thread Author #713
bassfisher6522: That's a early 2017 item for me. Thanks.
It's cheaper on Amazon right now. Link Removed
William B
I would say anytime you use a dust filter use one that is extremely air flow friendly. For super low budget folks I have used (used) dryer sheets no kidding. I was one of if not the 1st one that I knew of to use coffee filters to clean CPU grease about 16 years ago I posted that in ViaArena forums building a Soyo KT133 AMD system no one could believe it but they started doing it as well and it spread. Now, I certainly was not the one that started the used dryer sheet thing for dust filters, but I will tell you that Gain dryer sheets cut out perfectly do work and make the rig smell nice however It really only looks decent with a white case/system.
Air pressure I use a setup pretty similar to Kemical I don't get too fancy one 120mm front one back and one exhaust on top, and the other fan cutout on the top serves to simply keep air pressure nominal.
Jimbo22
If your running 2 exhaust fans and 1 intake fan: your front is an intake, your rear is an exhaust and the top mounted fan is an exhaust....then you're running negative air pressure.
Positive Air Pressure = more intake than exhaust
Negative Air Pressure = more exhaust than intake
Neutral Air Pressure = equal intake and exhaust
Do you have any pictures of that, the dryer sheet filter setup....I would love to see that in action.
William B
No I have not done that is some time no current pictures. I am aware about positive and negative air pressure but I do get really nice temperatures with this rig overall it's working out well for me.
brkkab
Thread Author #717
I'm not so, sure if I have negative airflow. 2 200mm. intake ( Front & side panel), 2 140mm intake bottom front of case, 140 mm. intake pivot fan blowing towards video cards & about 4-6" behind front 200mm fan.
Back of tcase 140mm. exhaust and top of case Arctic Liguid Freezer 240 in push/pull exhaust with it's stock low rpm fans.
Bitfenix Spectre Pro:
2 200mm. 900RPM & 148.72 CFM intake
4 140mm. 1200RPM & 86.73 CFM 3 intake & 1 exhaust
I need to pull my bed out to get to the box for the Arctic Liquid Freezer to get the fans full spec's.
I just wiped out on my mountain bike and asphalt cut up my left forearm and messed up my left palm/wrist less than half an hour ago.
I'm not into bandaids, so I'm leaving the 3" 1" cut's stay open, so they scab up faster. I just have to remember not to let the area touch anything.
It was fun lifting Sebastian onto my bed a few minutes ago.
brkkab
Thread Author #718
I use the coffee filter for cleaning cpu's/heatsinks.My case has dust filters everywhere a fan goes.
1 on the side panel, 2 on the bottom front/back,1 in the front panel and 2 200mm. up top.
My old pc has magnetic dust filter specifically made for it's case on the outside.
The back of my current case also has 4 grommeted holes for watercooling refill, etc. near the psu area.
brkkab
Thread Author #719
Bassfisher6522: That vacuum would be handy with radiators, as they're big dustbunny collectors if fans are connected to them.
Jimbo22
Yep...it's why I use my leaf blower and my air compressor....to really blow out those clogged heat sinks.
I take down my desktop and my son's desktop, take them to the garage, set up saw horses and put a piece of plywood across, set desktops on there so they are chest high and go to town cleaning. I do this about every 2 months and twice a year I brake them completely down for a thorough cleaning...
