The thread revolves around a user planning a new high-performance PC build, seeking advice on components such as CPU, cooling solutions, and graphics cards while managing a tight budget. Other users suggest alternatives, like choosing a cheaper CPU like the i3, and share experiences with cooling systems and hardware choices, with some emphasizing cost savings and others commenting on the specific components' performance. Overall, the thread reflects careful planning and community support for building a customized PC suited to the user's needs and financial constraints, amidst some personal health challenges shared by the original poster.
brkkab
I'm currently in the process of getting parts for a new computer build.
So far I have a Asus Maximus VIII Hero mobo and a Samsung 850 EVO 500GB. M/2 ssd for it. I'm also going to be re-using the Seagate Barracuda 3.0TB h.d , Intel 530 Series 400GB ssd (for Games), Lite On DVD-RW, Lite ON Blu-ray burner and memory card reader from my current pc.
I'm also going to be getting a NZXT Phantom 820 case. G-Skill Ripjaws-Z DDR 4 3200 ram (32GBS) and a Corsair HX-1000i psu for the new pc.
I need suggestions between the following part's for the new pc.
The heatsink is either going to be a EK-XLC Predator 240 or a Corsair Hydro Series H-100i GTX.
With either one, I'll be using 4 EK-Furious Vardar FF5-120 (3000rpm) fans in push/pull.
I also need help deciding between 2 GeForce GTX 4.0GB or 2 AMD Radeon 390X 4.0GB video cards.
I'm ordering a Intel Core i5 6600K cpu on Thursday and eventually plan on upgrading it to a Core i7 6700K in early 2017.
Keep in mind, I'm on permanent disability (Social Security) for life and can't afford to spend over $300.00 on a part/s in a month.
The pc won't be built until May as I won't have all parts until then minus the new video cards.
I'll be using my current GeForce GTX 760's until then, but they need to go back inn this pc, so I can sell it.
All suggestions appreciated between the AIO's and video card's.
P.S. PC will be running Windows 10 Pro x64.
I'm actually hoping for Tuesday or Wednesday. I have medical stuff Monday & Thursday.
Though, when I ordered my current pc's case, I received it the next day on a Saturday morning.
I very well may be building it tomorrow. I'll know sometime tonight when my tracking number is updated by FedEx.
I already have the number, they're just not as good as UPS or the USPS, in the tracking department. It probably won't give me any results until 11:00 P.M.
They think I'm going to pay for a M.2 mount that screws into the motherboard and was supposed to come with the motherboard.
The M.2 mount was missing too?
Damn! I'm guessing the store you got the moBo from won't help at all?
I don't know what ASUS are like for RMA's as I've always used Gigabyte boards. Fingers crossed it's resolved quickly for you.
brkkab
Thread Author #162
No, it's Asus's estore. That's the number he gave me.I know they're thinking that I'm gonna buy the M.2 mount & screw that was supposed to be in the motherboard's box. I'm not buying it and I let the guy know what I am going to do.
No full refund or new motherboard replacement with all parts for it, in it's box and I ruin them publicly. I don't want and won't accept a refurbed board.
I already know, they send there refurbs out really dirty and messed up. That information comes from their own forums.
brkkab
Thread Author #163
The're so called Customer Service is non-existent.I can't use the words I want to here to describe it, as I be banned. Let's say, I wouldn't recommend Asus to a non-friend and leave it at that
So what will you do now? Wait and see if ASUS cough up or save for a new board?
brkkab
Thread Author #165
Well my public Asus smear campaign is already started. I'll be ordering a new mobo in 10-11 days. The smear campaign also involved my refund. I'm just not waiting to be on the new pc.
brkkab
Thread Author #166
I know a few Senators, too. One is a ex-Senator due to age & stopping working. Him, I've pretty much known my whole life, as his daughter & I went to school together since we were 5 years old.
brkkab
Thread Author #169
Actually, I'm getting the Gigabyte GA-Z170X-UD5 (rev. 1.0) instead off the above link. I did a little more research after I posted.
I had a good look at the UD3/UD5 boards when I last upgraded. They have have extended warranties too if I remember correctly (although this only works if you live in the US, Europe doesn't seem to get the extra warranty stuff) In any case they are great boards and most Gigabyte boards come with a dual bios which can be handy.
brkkab
Thread Author #171
It has dual bios & 2 M.2 slots. With one of the M.2 slots you lose most of the sata ports. With the other M.2 slot, you only lose 1. I'm gonna have to double check with their support on which one only loses 1, as I need 4 sata ports for what I have now.
Yeah mines a Z97X chipset so only the one M.2 slot although I doubt I'll ever use it to be honest. They are a bit too pricey for my liking.
brkkab
Thread Author #173
Actually the prices aren't too bad for the one's your's will support. I got my Samsung 850 EVO 500GB M.2 which isn't one of the newer NVMe ones for like $150.00. The price has dropped since then. Your mobo I don't think supports the NVMe ones, so you can get the older ones pretty cheap.
They're really small, too. Probably about 1/16 - 1/32 the thickness of a flash drive.
Thanks for the heads up.. I though the price would drop eventually, so it's started already cool..
brkkab
Thread Author #175
Your welcome.
I'm thinking when I have the motherboard, that I'm gonna get Windows 10 Pro installed. Then after I have 10 updated, I'll be doing the drivers & overclocking it. Once that's done, I'm gonna copy 10's product key, put Windows 7 drivers on a flash drive and clean install 7 Pro atleast, until Edge supports extensions for everyone. I'll reinstall 10 when Adblock Plus, Web of Trust and my password manager works in Edge. Until that time Edge is useless to me and now Microsoft won't let you make IE 11 the default browser in a clean install of 10.
I know, I can make Chrome or Firefox as default, but that adds headaches with 10.
I've noticed enough little 10 bugs and Microsoft is more interested in adding new features first, that add even more bugs, before fixing 10's pre-existing bugs first.
It's dumb if you think about it. Say the Music app skips songs when you try to play a cd stored on your hard drive or ssd. We'll add a new feature to the Photos app and ignore the bug we know is in Groove.
We only care if someone buys music from our store.
Same thing with Movies & TV, it should be called Movies & TV Store, as we can't use a tv tuner with it to watch or record tv. They expect us to pay to download whatever tv or movie, we want to watch, when most of us already paid our cable/satellite providers, Netflix, Hulu or Amazon for. Why would we want to pay again for the same thing ???
Really? I've used Chrome since Win 10 was released and apart from some early teething issues it runs fine or at least has done so for me.
brkkab
Thread Author #177
No you misunderstood what I meant or I worded it wrong. Microsoft doesn't like it's competitors browsers being the default one. I use Firefox & Chrome way more than IE or Edge. In my opinion Edge sucks right now. No addons if you're not on a Insider/Beta build is b.s.
Then they update their apps for Insiders, but us regular non-beta users wait forever for them to fix their app's.
The Photos app and Mail app's are the worst one's I've noticed in Windows 10.
The Photos app will scan your photos fast in one update, say 2-3 minutes, Then the next update it get's will take 3+ hours to do the same thing.
On the Mail app in 10, they took it's best feature away that Windows 8 & 8.1 has. In 10 there's no box at the top that you can click on to delete numerous emails with 2 click's. Instead and I'll use Gmail, as a example. If you use Gmail, you have Inbox and All Mail. A lot of times you'll have duplicates of the same email in each. It's a huge pain in the ass deleted 35+ emails from Deleted or Trash one at a time. It isn't productive either, as your wasting extra time doing it one by one. They haven't seemed to realize in 10, that we can scroll down threw our email and make sure we're not deleting anything we don't want to and uncheck that item, like we did in Windows 8 & 8.1.
Personally, it cracks me up, when they can't figure out why other developers have stopped writing app's for Windows. They see these same bugs, as we do, notice Microsoft is more interested in new features and not fixing previous bugs first. That only adds more bugs and loses customers.
Think about this one to. Where would you rather get a pc game from ? The Windows Store,with limited game settings in the game options or Steam, Origin and Uplay, with full game options in the game's settings?
I would have to think long and hard before I bought anything, let alone a game, from the store. I stopped using Windows mail simply because i use Outlook and having two lots of the same messages gets a little wearing after a while. (and I use Gmail too lol)
I've been reading about the poor quality game options one gets with a game purchased through the Store although Microsoft have said things will slowly improve.... We'll see I guess.
brkkab
Thread Author #179
I stopped using Outlook since they released 2013. It now doesn't show all the folders for a Gmail account. I'd have to go into the Mail app to see them. I saw no reason to use both. The Mail app was ok in my opinion, until they released 10.
brkkab
Thread Author #180
I finally felt good enough today to get my 2 Corsair AF 140 fans in my new case and hook the cases sata cable for it's lighting up. Now all I need is a working motherboard. That I'll have within 2 weeks.
