brkkab
I'm currently in the process of getting parts for a new computer build.
So far I have a Asus Maximus VIII Hero mobo and a Samsung 850 EVO 500GB. M/2 ssd for it. I'm also going to be re-using the Seagate Barracuda 3.0TB h.d , Intel 530 Series 400GB ssd (for Games), Lite On DVD-RW, Lite ON Blu-ray burner and memory card reader from my current pc.
I'm also going to be getting a NZXT Phantom 820 case. G-Skill Ripjaws-Z DDR 4 3200 ram (32GBS) and a Corsair HX-1000i psu for the new pc.
I need suggestions between the following part's for the new pc.
The heatsink is either going to be a EK-XLC Predator 240 or a Corsair Hydro Series H-100i GTX.
With either one, I'll be using 4 EK-Furious Vardar FF5-120 (3000rpm) fans in push/pull.
I also need help deciding between 2 GeForce GTX 4.0GB or 2 AMD Radeon 390X 4.0GB video cards.
I'm ordering a Intel Core i5 6600K cpu on Thursday and eventually plan on upgrading it to a Core i7 6700K in early 2017.
Keep in mind, I'm on permanent disability (Social Security) for life and can't afford to spend over $300.00 on a part/s in a month.
The pc won't be built until May as I won't have all parts until then minus the new video cards.
I'll be using my current GeForce GTX 760's until then, but they need to go back inn this pc, so I can sell it.
All suggestions appreciated between the AIO's and video card's.
P.S. PC will be running Windows 10 Pro x64.
I'm actually hoping for Tuesday or Wednesday. I have medical stuff Monday & Thursday.
Though, when I ordered my current pc's case, I received it the next day on a Saturday morning.
I very well may be building it tomorrow. I'll know sometime tonight when my tracking number is updated by FedEx.
I already have the number, they're just not as good as UPS or the USPS, in the tracking department. It probably won't give me any results until 11:00 P.M.
brkkab
Thanks, that's the one I couldn't think of CrystalDiskMark. Here's mine on the 840 Pro on this pc.
brkkab
Hey, how are you guy's getting your snipped screenshots to show bigger here?
With Crystal Disk Mark in normal mode.Anything over 500 Read and Write I am happy with.
Excellent! It's always nice to see what other users of similar gear are getting so thank you.
brkkab
I just click on upload a file, select the file and click ok in the window that pops up.
After the photo has uploaded you should see these choices:
An image from 'Need help deciding on 2 components for new pc build'. Screenshot of an online forum's reply box with options to insert and manage an uploaded image file.
XAOS
Member
The Thumbnail and Full Image options are right at the bottom of the screen, and easy to miss unless you are aware they are there.
brkkab
Oh, ok.
I just had to email Arctic Cooling back. They had it mixed up on the pieces I need. They thought it was the backplate and the cpu blocks retention ring. I had to open OneDrive up and open the manual and snip/circle what I need. The backplate, it's 4 mounts that hold it to the motherboard and the 4 thumbscrews that hold its cpu block to the motherboard. Bad with circling. I need my new glasses bad.
An image from 'Need help deciding on 2 components for new pc build'. The images show computer cooling accessories including standoffs, screws, fan set, backplate, and retention rings.
brkkab
I just learned something new about the LG 25UM58-P monitor. I can change all the monitors settings inside of Windows, instead of messing with it's buttons on the bottom of the monitor. LG has a program called OnScreen Control that gets installed in Windows and controls all the monitors settings. I can also run 3 programs, each taking up 1/3 of the full screen side by side.
William B
Ah yes, split screen capability. Nice :) although I like my two monitors when I game sometimes I watch a DVD, or view a news feed, or twitch on one while gaming on the other. Usually though, I monitor voltages and temperatures on the other screen with HWMonitor while gaming.
brkkab
2 would be nice. I've got some drawbacks there, though. My desk isn't big enough and my bedroom is kind of out of room.
brkkab
I definitely like being able to use the OnScreen Control software inside Windows. When I hook my i1 Display LT up to calibrate my monitor, I can just open that software to make various needed adjustments instead of messing with the button on the bottom of monitor. The monitor has one big circle with 5 different areas for each mode and adjustment.
brkkab
Arctic Cooling has my backplate, mounts, etc. set to ship to me. It's coming from Germany. They said it should take 7-10 days to arrive. My monitor is on the FedEx truck out for delivery.
nmsuk
This build is epic. Seems to be neverending with twist and turns along the way. Reads a little like it would if you were Tom Clancy ;) Hopefully soon you'll have it all.
brkkab
I forgot to mention this earlier. NVIDIA released new 368.39 drivers yesterday for the GTX 6**, 7** & 9** cards. I also heard they're supposed to release new drivers for the GTX 1080 & 1070 later today.
Apparently the new GTX 1080 & 1070 has a bug that the new driver fixes.
As far as the 368.39 driver. I've run all of #DMarks benchmarks on it. I've run WWE 2K16's in-game benchmark on it. I've watched some videos on YouTube with it.
It doesn't appear to be buggy, like the last driver, so far.
brkkab
No issues so far with it. The one prior to it had sound issues. If you watched a YouTube video, you didn't get any sound.
I didn't get any issues with the last driver or at least none that i know of..
