The thread revolves around a user planning a new high-performance PC build, seeking advice on components such as CPU, cooling solutions, and graphics cards while managing a tight budget. Other users suggest alternatives, like choosing a cheaper CPU like the i3, and share experiences with cooling systems and hardware choices, with some emphasizing cost savings and others commenting on the specific components' performance. Overall, the thread reflects careful planning and community support for building a customized PC suited to the user's needs and financial constraints, amidst some personal health challenges shared by the original poster.
brkkab
I'm currently in the process of getting parts for a new computer build.
So far I have a Asus Maximus VIII Hero mobo and a Samsung 850 EVO 500GB. M/2 ssd for it. I'm also going to be re-using the Seagate Barracuda 3.0TB h.d , Intel 530 Series 400GB ssd (for Games), Lite On DVD-RW, Lite ON Blu-ray burner and memory card reader from my current pc.
I'm also going to be getting a NZXT Phantom 820 case. G-Skill Ripjaws-Z DDR 4 3200 ram (32GBS) and a Corsair HX-1000i psu for the new pc.
I need suggestions between the following part's for the new pc.
The heatsink is either going to be a EK-XLC Predator 240 or a Corsair Hydro Series H-100i GTX.
With either one, I'll be using 4 EK-Furious Vardar FF5-120 (3000rpm) fans in push/pull.
I also need help deciding between 2 GeForce GTX 4.0GB or 2 AMD Radeon 390X 4.0GB video cards.
I'm ordering a Intel Core i5 6600K cpu on Thursday and eventually plan on upgrading it to a Core i7 6700K in early 2017.
Keep in mind, I'm on permanent disability (Social Security) for life and can't afford to spend over $300.00 on a part/s in a month.
The pc won't be built until May as I won't have all parts until then minus the new video cards.
I'll be using my current GeForce GTX 760's until then, but they need to go back inn this pc, so I can sell it.
All suggestions appreciated between the AIO's and video card's.
P.S. PC will be running Windows 10 Pro x64.
I'm actually hoping for Tuesday or Wednesday. I have medical stuff Monday & Thursday.
Though, when I ordered my current pc's case, I received it the next day on a Saturday morning.
I very well may be building it tomorrow. I'll know sometime tonight when my tracking number is updated by FedEx.
I already have the number, they're just not as good as UPS or the USPS, in the tracking department. It probably won't give me any results until 11:00 P.M.
brkkab
Thread Author #1,701
An image from 'Need help deciding on 2 components for new pc build'. Both images show Disk Cleanup windows for different drives offering to delete 0 bytes from caches and recycle bins.
Did you do a clean install of FCU ?
Disk Cleanup does Drive C: as it normally does, but drive D; & E;, it shows no progress and just stays on the screen, until I click on something else, then the Disk Cleanup windows for each disappears.
All it cleans on either of those is the Recycle Bin (which I empty myself) and downloaded DXstuff. I'll upload a screenshot of each.
The Store downloaded Themes & Edge addons may have been fixed. I've gotten at least 3 Store updates since last Tuesday.
System Image fails at the very end, it worked fine prior to FCU's update for me. That's o.k., every tech/pc site stated MS was removing it, so I went back to Macrium Reflect just before FCU's release.
brkkab
Thread Author #1,703
Weird, then again from everything I've heard different people are experiencing different things with it.
My old pc runs completely fine with it, too. Funny thing is I just did the upgrade install on it with the flashdrive I created of FCU from CU.
Old pc is all AMD, too. (990FX movo & FX8350, but 2 MSI GTX 760's.
This one's all Intel, except for my RX 480.
nmsuk
I really like it. Had non of the memory issues others have had with Ryzen. Overclocks well and so far has been very stable and issue free.
brkkab
Thread Author #1,706
I may go with one of the Asrock Fatality motherboard's. They appear to be the only one with the amount of motherboard USB 2 & 3 ports I need. I need 2 of each in the front for my case and my memory card reader. All the others appear to have USB 3.1 & one usb 2 ports.
Then the rest of the X370 boards don't have enough back panel usb ports for my needs.
That and I haven't heard that them back panel usb 3.1 ports are compatible with usb 3 devices & cables.
As far as the back panel usb ports I need:
1:keyboard USB 2
1:mouse usb 2
1:webcam usb 2
1: racing wheel usb 2 (I think)
1: magicJack usb 2
1:external hdd usb 3
1: Xbox 360 controller usb 2
My case top has:
4 usb 2 ports
2 usb 3 ports.
For ny memory card reader I already have a usb 2 - usb 3 motherboard adaptor cable for it.
Currently my memory card reader is plugged into one of the 2 usb 3 motherboard ports and the case top uses the 2 usb 2 ports and other usb 3 motherboard ports.
The X370 Asrock Fatality has the same layout on the motherboard, usb port wise for the case & memory card reader
brkkab
Thread Author #1,707
As far a the G-Skill Flare X DDR4 3200 I'm gonna be getting, I already know I'll have to downclock it to DDR4 2933, as I'm going with 2 kit's for 32GBs.
Whichever cpu I get, I don't think I'm overclocking it.
brkkab
Thread Author #1,708
I'm changing up what I get in November.
Now I'm gonna get the following tomorrow morning.
1. Logitech G Driving Force Shifter
2: $50.00 or $75.00 Newegg gift card toward's December's Logitech G920 Criving Force Racing Wheel
3. Forza Horizon 3 Expansion Pass
4: Dungeons 2 - All DLC
5: Outland - Artbox and OST
6: Shadow Warrior-_ Special Edition Upgrade
7: Need For Speed Payback
December's still looking like I'm getting the Logitech G920 Driving Force Racung Wheel
Then I'll only have all the DLC for Killing Floor left to get.
It's all over $14*.00, so it can wait.
brkkab
Thread Author #1,710
Yeah, that one slipped by me last Friday. I downloaded & installed it Monday.
I didn't need the Shadow Warrior dlc. Apparently I already had it without knowing it.
The dlc for Forza Horizon 3 fixed the game saving my setting's.
Now I'm going to mess with my Dungeons 2 & Outland since I have all their dlc now.
I ordered the shifter and pre-ordered Need For Speed Payback.
I didn't get the Newegg gift card.
I should still be able to swing the G920 in December.
brkkab
Thread Author #1,714
I'll try it out now in 3DMark.
I had to pre-download Need For Speed Payback first and restart my pc.
Now onto benching the new driver.
brkkab
Thread Author #1,715
3DMark scores:
Time Spy: 4617 - Increase from 2 drivers ago 4601
Fire Strike: 12372 -Increase from 2 drivers ago 12000
Fire Strike Extreme -6354 - Decrease from 2 drivers ago. 6409
I'll do PCMark 10 later.
I never benchmarked last Friday's driver.
brkkab
Thread Author #1,716
PCMark 10 scores dropped down, too.
PCMark 10 Current Score :6148 - 2 drivers ago score: 6812
PCMark 10 Extended current score: 6940 - 2 drivers ago score 7422
nmsuk
Firestrike 13311 up from 12230
Timespy 4806 up fro 46xx
brkkab
Thread Author #1,718
nmsuk: Are you experiencing the same issue with 3DMark in Steam that I am.
Issue over the last 1 1/2-2 weeks, #DMark's "Compare Results Online" does nothing now. It doesn't open a web browser to see your previous results, add the current results to your online saved results, etc.
PCMark * PCMark 10 don't have this issue.
I tried uninstalling and removing all 3 programs, all their folders and all Futuremark folders and registry key's.
I then restarted my pc, reinstalled each, restarted my pc after each install. #DMark still has that issue.
brkkab
Thread Author #1,719
It worked fine at first after the clean install of Fall Creators Update, so Windows 10 FCU isn't the problem causer, I don't think.
nmsuk
I've had it happen a couple of times, the problem so far has always been their end.
