brkkab
I'm currently in the process of getting parts for a new computer build.
So far I have a Asus Maximus VIII Hero mobo and a Samsung 850 EVO 500GB. M/2 ssd for it. I'm also going to be re-using the Seagate Barracuda 3.0TB h.d , Intel 530 Series 400GB ssd (for Games), Lite On DVD-RW, Lite ON Blu-ray burner and memory card reader from my current pc.
I'm also going to be getting a NZXT Phantom 820 case. G-Skill Ripjaws-Z DDR 4 3200 ram (32GBS) and a Corsair HX-1000i psu for the new pc.
I need suggestions between the following part's for the new pc.
The heatsink is either going to be a EK-XLC Predator 240 or a Corsair Hydro Series H-100i GTX.
With either one, I'll be using 4 EK-Furious Vardar FF5-120 (3000rpm) fans in push/pull.
I also need help deciding between 2 GeForce GTX 4.0GB or 2 AMD Radeon 390X 4.0GB video cards.
I'm ordering a Intel Core i5 6600K cpu on Thursday and eventually plan on upgrading it to a Core i7 6700K in early 2017.
Keep in mind, I'm on permanent disability (Social Security) for life and can't afford to spend over $300.00 on a part/s in a month.
The pc won't be built until May as I won't have all parts until then minus the new video cards.
I'll be using my current GeForce GTX 760's until then, but they need to go back inn this pc, so I can sell it.
All suggestions appreciated between the AIO's and video card's.
P.S. PC will be running Windows 10 Pro x64.
I'm actually hoping for Tuesday or Wednesday. I have medical stuff Monday & Thursday.
Though, when I ordered my current pc's case, I received it the next day on a Saturday morning.
I very well may be building it tomorrow. I'll know sometime tonight when my tracking number is updated by FedEx.
I already have the number, they're just not as good as UPS or the USPS, in the tracking department. It probably won't give me any results until 11:00 P.M.
nmsuk
You want the top one, it's full speed when the chipset isn't. The M.2 on the chipset is shared with SSD ports. Top one is straight to the CPU.
brkkab
Considering my m.2 SSD is only a 850 EVO and not one of the newer (50/960 one's, the bottom should be fine.
Besides using the top make's it like your using SLI or Crossfire and your video card runs at x8, instead of x16 speed.
Considering I'll be using Samsung Magicin's RapidMode and Asus's RamCache like I am now, the speed's will be like the screen shots of it on the previous page.,
nmsuk
Not true, cpu has 24 lanes 16x are for GPU, 4 are for M.2 and the other 4 link to the chipset. So top will always be better
brkkab
I'm going by the various reviews I saw. derBauer recommends use the lower m.2 slot, as the top one decreases the video card's speed tp x8.
Hard not to believe him, as he's one of the best known over-clocker's going today.
brkkab
JayzTwoCents is tops for watercooling stuff.
He did some testing with the 2700X and found something.
He used G-Skill Sniper X with the Crosshair VII Hero (Wi-FI) and 2700X cpu.
Not necessary to overclock the 2700X further than 4.2-4.3GHz. Just stop their and set the ram toDOCP1, Docp2 and you score really high in Cinebench
He also overclocked the ram to DDR4 3600 and the scores increased a bit.
Side Note: With the Crosshair VII Hero (Wi-Fi), it looks like I'll be able to put my EK-XLC Predator 240 1.1's add-on fan kit for push/pull.
It looks according to pictures that the mobo doesn't have as much plastic covering on the top like my Maximus VIII Hero does.
I guess I'll find out when I do it.
I have planned to fully pull the Predator out of the case just before removing the Maximus VIII Hero and putting in the Crosshair VII Hero (Wi-Fi).
I may drain, flush & refill it then, too.
nmsuk
I'm using the top m.2 is at pcie 3x4. My GPU is @16x so I'm afraid he is wrong. He is a great overclocker though.
Sent from my CLT-L09 using Tapatalk
brkkab
That could also be something that was changed in the various X470 mobo's.
I forget who did the video, but he always does videos of vrm take apart & testing.
Apparently the Crosshair VII Hero & Hero (Wi-Fi) have better (more powerful) vrm's than Gigabyte, MSI and Asrock have on their X470 mobo's.
The one thing I'm waiting to find out on if it was fixed in the X470 mobo's is the ram speeds when you have a ll 4 ram slot's in use.
I haven't seen anyone touch on that, yet out of any reviews done.
For instance if I fill all 4 slots with the Sniper X DDR4 3400 ram, will they run at the 3400 speed or only at 3200 speed ?
Guess I'll find out soon enough.
nmsuk
That's actual hardcore overclocking/Buildzoid
nmsuk
Probably 4 dimms will do 2933 possibly 3200 if lucky
brkkab
Yeah, either that or 3200.
New AMD Adrenalin 18.5.2 drivers released today.
#DMark scores:
Time Spy - 4365 - up
Fire Strike - 11752 - yp
Fire Strike Extreme -6011 -down
PCMark 10 scores:
PCMark 10 - 6389 -up
PCMark 10 Extended - 7104 -down
brkkab
Apparently from a article Tom's Hardware posted on the new driver's, they were supposed to be for a new Oculus Rift & Steam VR game.
The game is on hold for now.
They're now just bug fix drivers apparently.
Article link : AMD Releases Radeon Software Adrenalin Edition 18.5.2
Now onto waiting a hour or so to order the 2700X.
After I do that I need to look up some medical conditions I never knew that I have.
Apparently I have 28 different medical conditions.
Probably 22-25 of them are linked to my diabetes.
brkkab
AMD Ryzen R7 2700X cpu is now ordered from Newegg.
Just got Just Cause 3 XL on Steam, too.
brkkab
MY cpu will be here Tuesday.
Just received the tracking info. from Newegg.
brkkab
Unexpected expense this morning for Sebastian.
He'd been shaking his head and scratching at his left ear since Tuesday.
I took him to the veterinarian this morning to get it checked out.
Apparently he has a serious left ear infection.
I figured the medicine for it and the visit would be $50.00, boy was I surprised.
$129.70 for the visit, the 2 medicines for the infection and one of his flea/tick/heartqorm prevention pills.
That's o.k., though.
He's already starting to act like his normal self again.
brkkab
chemical: Long ago.
Now the MOBO, cpu & ram are being replaced and the current MOBO, cpu & ram are going in my old pc.
brkkab
Ryzen has arrived.
The 2700X cpu has, at least.
Now onto the MOBO next.
An image from 'Need help deciding on 2 components for new pc build'. A man holds an AMD Ryzen 7 2700X processor box showing front, back, and top views.
brkkab
Shame, I'll never use the cooler.
I may eventually upgrade my water -cooler's Vardar non-rgb 120mm. fans for the just released Vardar rgb 120mm. fans.
