If you are talking about Windows Explorer than no it won't because the file system for the drive is likely HFS or HFS+ or something similar and completely foreign to Windows OS.
I believe that is what the software is for. Maybe give the 5 day free trial of the software I linked to above a try and see if that gets you anywhere.
If neither device manager nor disk management sees the drive then the problem may be something else entirely.
- Joined
- May 16, 2010
- Messages
- 5,688
Quite a lot of methods. For small quantities of data you can email the files. For large transfers you can use methods described as on here:
How to share files and folders between Windows and OS X using Parallels – Simple Help
Trouble
Noob Whisperer
- Joined
- Nov 30, 2009
- Messages
- 13,714
